EVOMS Intake Installation Problems
Old Feb 19, 2011 | 11:09 AM
Diablo360's Avatar
Diablo360 is infamous around these parts
Has anyone else had problems installing this thing on their car? I thought it would be a simple enough process, and I'm not a total noob when it comes to doing DIY work...... The thing doesn't fit properly (has a gap near the air inlet), has missing hardware, and the installation instructions on the EVOMS website are for a 997 and don't show you how to install the brackets and hardware that aren't pictured.
I'm about to throw this thing back in the box and ship it back. Am I missing something here? Can anyone else chime in?
Old Feb 19, 2011 | 11:14 AM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
i have the intake as well and the install was easy.My case i have to little adjust the plenum position fit the inlet tube perfect.
I recomend first conect everything before you attach the intake to the frame with the 13 mm bolt.
Do you have the relocating bracket included?
I would say the fit is 8/10 but these are aftermarket products so give a little close eye on fitment.
Old Feb 19, 2011 | 12:24 PM
Diablo360's Avatar
Hmm.... Ok, I have the relocation bracket, but have no idea where it goes. The directions on there website don't show it lol. Are there any guides online? I found this thread: (http://forums.rennlist.com/rennforum...u-upgrade.html) but there are no pics......
Old Feb 19, 2011 | 02:06 PM
bjarne996's Avatar
bjarne996 is infamous around these parts
I also thought something was missing when I installed mine.
But, the thing actually only needs the one attachment in the middle (one screw to the original airbox attachment point) in addition to airtube.
I ended up:
1) loose fitting the middle attachement screw
2) loose fitting the airtube
3) adjust the airtube so that the inlet snorkel fits the plastic air duct in the engine lid.
4) tighten the airtube fitment, then tighten the middle attachment screw
Remember that since the inlet snorkel fits around the plastic air duct in the engine lid, instead of inside it like the OEM airbox, exact fitment will not be essential. My intake snorkel seemed to hit the plastic air duct 1/2 an inch to the right. However, due to the much bigger intake snorkel of the EVOMS compared to the OEM, I do not think this will impede performance much.
Old Feb 19, 2011 | 02:11 PM
fast996's Avatar
fast996 is infamous around these parts
does your evoms intake have any draining for rain \ water ?
Old Feb 19, 2011 | 02:47 PM
Diablo360's Avatar
Yup mine does. right in the box where the filter is there is a hole at the bottom.
Old Feb 19, 2011 | 04:24 PM
bgrpph's Avatar
bgrpph has a spectacular aura aboutbgrpph has a spectacular aura aboutbgrpph has a spectacular aura about
evoms bracket
not sure if this is the question but- i have 2002 996 3.6 and previously had EVOMS CAI on car
-on the 996 the relocation bracket goes on the air pump to move it more to the left a bit so the EVOMS CAI doesn't hit it- I believe this bracket is not needed on the 997 but may be wrong.
to install bracket-unplug the wire to air pump- take off old bracket off car with air pump attached and install new bracket onto air pump and reinstall in car- you'll see the pump is now more outward toward fender than before which allows CAI to fit properly. if you try to install the CAI without moving the air pump it won't fit correctly on the 996 as it will hit the pump and/or bracket and not allow it to line up correctly. hope this helps.
Old Feb 19, 2011 | 07:01 PM
Diablo360's Avatar
Wow thanks. I'll give it another shot tomorrow. I pulled my hair out trying to figure this out today.....
Old Feb 21, 2011 | 03:09 PM
bjarne996's Avatar
How did you do?
Is the EVOMS now correctly fitted?
Old Feb 21, 2011 | 03:26 PM
Diablo360's Avatar
Hey, thanks for following up. I got everything installed and surprisingly it fits well. The air inlets line up perfect, and nothing rubs or scrapes. It's kind of odd because my kit came with the relocator bracket for the secondary air pump, but the holes on the new bracket didn't line up with the holes on the air pump. It looks like the holes on the bracket were made for a smaller air pump from a different year. Anyways, I didn't end up needing the bracket......
As luck would have it, when I went to start my car, the battery was dead because I left the engine bay open for too long...... I'm too lazy to jump start it so I'm waiting for my new batter to arrive lol. I'll report back after I take it out for a spin.
Old Feb 21, 2011 | 03:37 PM
bjarne996's Avatar
Neither did I on my 98.
Glad it worked out.
Old Mar 6, 2012 | 06:55 PM
romys996's Avatar
romys996 is infamous around these partsromys996 is infamous around these parts
Does anybody know where I can buy the relocation bracket? I bought a used CAI that didn't come with the relocation bracket. I understand the relocation bracket it not required on 997's. If anybody has one sitting around, I'm willing to buy it from you.
Diablo, do you still happen to still have it? Since you didn't use yours?
Old Mar 6, 2012 | 06:57 PM
gu9cci's Avatar
bracket
Call Evoms
Old Mar 6, 2012 | 08:11 PM
romys996's Avatar
Thx for the feedback everyone. I'll be calling EVOM tomorrow.
Old Mar 15, 2012 | 11:26 AM
Mike 996C4's Avatar
Mike 996C4 is infamous around these parts
Thumbs up Evoms rocks
Dude call EVOMS ... they sent me out a used one for FREE ... I bought my CAI from Ebay ... didnt come with the bracket ... called them and they are real nice people ... Legit company ... my upgrades will be from EVOMS!
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
km90265
Aug 31, 2015 11:00 AM
mlife2878
Aug 26, 2015 07:02 PM
ritchrwi
Aug 20, 2015 05:19 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
