Engine Cleaning/Shampoo
Old May 8, 2011 | 08:56 AM
Sosoomi1's Avatar
Sosoomi1 is a jewel in the roughSosoomi1 is a jewel in the roughSosoomi1 is a jewel in the rough
I always think that a vehicle, whether it be a car, boat or motorcycle, runs better with a clean engine... agree or not... they certainly look better.
In the old days it didn't seem so hard to find a guy with a steam cleaning service that would give the engine compartment a good once over but with the newer engines and all the electrical components I am a little wary.
Has anyone cleaned their 996 engine bay and have any recommendations to products, techniques, or do's and don'ts?
Cheers....
Old May 8, 2011 | 11:37 AM
tarzancoe's Avatar
tarzancoe is infamous around these parts
Just do it with a pressure water hose and bleach. If the engine stops running, just replace it with a new one
Old May 8, 2011 | 11:40 AM
Sosoomi1's Avatar
Well thanks for the heads up..... is it just me or the thin air in Big Bear? Haha
Old May 8, 2011 | 11:41 AM
tarzancoe's Avatar
Gotta be, right, ahah
Old May 8, 2011 | 11:43 AM
tarzancoe's Avatar
Actually I am looking into it too... just got a Techart carbon airbox cover so need to do some cleaning there. It should be arriving soon from Germany.
Old May 8, 2011 | 01:25 PM
nittanyguy1's Avatar
nittanyguy1 is infamous around these parts
Old May 8, 2011 | 04:09 PM
aemr1968's Avatar
aemr1968 is infamous around these parts
Actually pretty easy to do.
1- cover radiator with plastic
2- spray WD-40 on wires
3- apply engine degreaser, wait 20 min, remove with water, repeat as needed
4- air dry engine or let dry but make sure there are no excess water or deposits before next step
5- apply engine detailer on everything black i.e., air filter cover, hoses, etc
6- clear radiator
7- wait about 1 hr before starting up engine
I use Meguiar's engine cleaner and detailer.
Hope it helps.
Old May 8, 2011 | 06:34 PM
tarzancoe's Avatar
Tx for tips, will follow them.
Old May 8, 2011 | 06:58 PM
Sneaky Pete's Avatar
Sneaky Pete has a spectacular aura aboutSneaky Pete has a spectacular aura about
6- clear radiator
Hope it helps.
I have used simple green. Spray it on heavy and everything. Cover the inlet to the air box with a plastic bag and tape it tight. But you got me lost on the radiator. Its up front not in the engine bay. Let trhe simple green soak for 20 minutes and use a pressure washer to rinse.
Old May 8, 2011 | 07:01 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Shops don't do it anymore due to all the Environmental laws..
they would have to store that waste water and have some company remove it as hazardous waste.which would cost a fortune.
Old May 8, 2011 | 08:28 PM
aemr1968's Avatar
meant alternator
Old May 9, 2011 | 12:15 AM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Jul 29, 2019 11:13 AM
saline
Oct 7, 2015 07:29 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
