Help Changing a part
Old Jun 12, 2011 | 10:35 PM
CoolHand's Avatar
CoolHand is infamous around these parts
Anybody change out the release lever for the hood on the Pcar?
I have a replacement lever thanks to Aldo at Suncoast. What I need is some guidance, I really don't want to go in removing parts.
Old Jul 24, 2014 | 01:52 PM
alfredoborbafilho's Avatar
alfredoborbafilho is infamous around these parts
Hello CoolHand! I am in same situation as you ! did you solve it ? how to disassembly the plastic parts to access the lever to change it?
Regards,
Old Aug 5, 2014 | 01:43 PM
I changed this part last week ...and it was piece of cake to change it! just need to find and loose 3 allen 4,0 mm bolts on side of plastic parts inside de cab, after remove 3 plastic plugs covering the bolt access close to the seat then, loose thoss 3 bolts like 3 turns , remove the complete plastic cover trim directing it to upside ,then remove the trunk cables for both levers removing a bolt with a 1,0 mm allen wrench and the cable from the fixing plastic slot.so with the complete assemble in a bench you can change the lever removing the pin lock and the spring ..do the reverse operation to put it back ...and voilá!done!it´s require minimum experience and can be done in 30 minutes at most!
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
