weird start up problem, help pls!
Old Sep 10, 2011 | 05:50 AM
ytyper's Avatar
ytyper is just really niceytyper is just really niceytyper is just really niceytyper is just really niceytyper is just really nice
I have a 2003 Carrera coupe with 27000miles. Every day first start up or warm start up (engine totally warm up turn off then start up around an hour), it will take around 10 sec to start up the engine. But when the engine start up it will just drive strong without problem and no engine light too. After the long crank to start up the engine then turn it off right the way, then it will start up in 3-4sec like normal.
I have changed new spark plugs, new coils, speed sensor, and air filter. But still no help.... So hope someone can help me here please.
Old Sep 10, 2011 | 07:25 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
I don't know about 996's specifically but that sounds like a possible fuel pump issue. The check valve may be allowing pressure to bleed off when the car sits so it takes longer than it should to build back up. If you can put a fuel pressure gauge on it. If not, try putting the key in the run position for 10 seconds then try to start it. I'm not sure how loud the 996's fuel pump is but you should be able to hear it. If it starts up much easier then it is probably related to your fuel pump. If not, that's something ruled out.
Old Sep 10, 2011 | 02:57 PM
ytyper's Avatar
Thanks for the reply! When turn ignition on, I hear a noise from the front for around 2 sec so I think the fuel pump at least working. But I will try to stay 10sec and start see will it help. Thanks a lot
Old Sep 10, 2011 | 03:09 PM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
to check if it is actually fuel pressure bleeding off, try to turn the ignition (not all the way to start the car but till you her the fuel pump working, do this 3-5 times to build fuel pressure, if it starts then it confirms it...if not you have to look else where...
Old Sep 10, 2011 | 03:13 PM
sinKing's Avatar
If the fuel pump only stays on for a couple seconds then I agree with below.
Old Sep 10, 2011 | 03:18 PM
ytyper's Avatar
Just wondering how long the fuel pump sound should stay? I only hear mine with just 2 sec after turn the key at on position then will be quiet.
Old Sep 10, 2011 | 03:19 PM
sinKing's Avatar
I can't get specific on 996's but that is pretty standard.
Old Sep 10, 2011 | 03:26 PM
ytyper's Avatar
Ok thanks again, I will try later and hope that's the problem. Otherwise really have no idea what's going wrong. Everything's is good just long crank
Old Sep 10, 2011 | 06:02 PM
jeneric996's Avatar
jeneric996 is infamous around these parts
Maybe the idle control valve(?)
You didn't mention a check engine light so your vacuum lines should be good.
Old Sep 10, 2011 | 09:40 PM
tarzancoe's Avatar
tarzancoe is infamous around these parts
Old Sep 11, 2011 | 07:39 AM
ytyper's Avatar
Originally Posted by tarzancoe
My car don't have stalling problem, it drives good in cold or hot actually. Just problem on first start up each day or drive back to work after 10miles, then try to start up after an hour then it usually will took longer time to crank, or even first crank won't start then crank again will just start right the way.
Will it be purge valve, gas filter, MAP sensor ?.....
Old Sep 15, 2011 | 07:30 PM
ytyper's Avatar
I have custom wire to give fuel to engine, the car start right the way in any condition now..... so I m sure is because of the fuel delivery problem now...... probably is the fuel pump module.
Old Sep 15, 2011 | 07:34 PM
sinKing's Avatar
Good to see you're narrowing it down. As a possible cheap solution try some Techron or other fuel SYSTEM cleaner.
Are you having any driveability problems? It sounds like it is just the hard cold start now. If that's the case I would try the cleaner for at least two tank before throwing serious money at it unless the driveability starts to go down.
Old Sep 15, 2011 | 08:34 PM
ytyper's Avatar
Thanks..... I don't have any drivability problem and it actually drive strong too.... There is something block the fuel to the engine before start.
Old Sep 17, 2011 | 08:02 AM
blown's Avatar
blown is infamous around these parts
I just had this exact problem with my 2002 a4, I drove it around for about 3 weeks untill it eventually jut died. It was the fuel pump.
Mark @ AIM Performance
Sep 22, 2015 09:17 AM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
