Newbie from So Cal/Engine Rebuild
Old Oct 17, 2011 | 07:55 AM
danl's Avatar
danl is infamous around these parts
Hello all,
New owner here, looking for a So Cal shop to do a rebuild or if possible ( I think the IMS bearing blew up) just do that part of the motor. I am just getting into this project and have been doing some research, but would really appreciate more input... I have read some of the horror stories and do not need that in my families lives, finacially or mentally.
Thanks guys,
D
Old Oct 17, 2011 | 09:05 AM
logray's Avatar
logray is infamous around these partslogray is infamous around these parts
If you are concerned about mental health, and you think the IMS bearing blew up. The best thing you can do for the car is not run it until it is properly diagnosed. Have it towed to a shop.
Here comes the bad part, if the IMS bearing did blow up, depending on how much collateral damage there was - you are looking at the price of a replacement engine however you look at it.
If you somehow caught the IMS bearing before it blew up, then bearing retrofit costs range anywhere from $600 DIY to $2000 if done by a shop.
Anyways, this is all just "theoretical" until you have someone knowledgeable look at it. It could be something simple.
Old Oct 17, 2011 | 11:59 AM
porschenoofs's Avatar
porschenoofs is infamous around these parts
Rebuild
Auto Strasse in Costa Mesa does a lot of 996 engine rebuilds. Talk to Robert.
Old Oct 17, 2011 | 01:09 PM
danl's Avatar
Thanks Guys, It was shut off right after the sound of a chain bouncing around inside of a tin can started and has not been run again. It will be flat bedded anywhere it gets taken to.
Old Apr 13, 2012 | 06:11 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
danl- what was the outcome on the repair?IMS or something minor
Old Apr 16, 2012 | 08:36 PM
Mother's Avatar
Mother is infamous around these parts
+1 had them rebuild mine couple years ago and still running strong.
Thunder915
Oct 1, 2019 07:34 PM
alpha motoring
Oct 2, 2015 12:04 PM
DYL 911
Oct 1, 2015 02:47 PM
cpaulPHL
Sep 24, 2015 03:38 PM
andbos
New Member Introductions
Sep 10, 2015 10:43 AM
