Ignition problems..Symptoms
Old Apr 21, 2012 | 09:16 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
Help! Having difficulty removing or inserting my key into the ignition. Once it's in, car runs fine except wipers don't work, a/c nothing comes out but display appears to be working. When I got home and removed the key the system alerted me that key was still in the ignition. Is it the ignition switch? I have an extended warranty that I never used and might go ahead and use it. Replacement of switch doesn't appear to difficult. Thanks for any advice. Was told TRE in North Hollywood does excellent work? Agree? Thanks.
Old Apr 21, 2012 | 09:55 PM
rrrruben's Avatar
rrrruben is infamous around these parts
I had the same issue a few months back. I ignored the issue until the ignition key could not be inserted. Luckily, my P-car was in my driveway. Replace the ignition switch before it completely fails. Your symptoms indicate failure is inevitable. The part is cheap: http://www.pelicanparts.com/catalog/..._pg1.htm#item3 . I applied the DIY. An easy DIY on paper, but it's placement made it extremely difficult to address, and time consuming. Apply your warranty. Good luck.
Old Apr 22, 2012 | 11:39 AM
911ANIMAL's Avatar
911ANIMAL is infamous around these parts
I hade the same problem last year, got worse every time i turned the key. Changed the ignitionswitch took about 40min and problem gone. Bought the switch for Audi.
Old Apr 22, 2012 | 06:36 PM
911C4S's Avatar
Thanks for the advice! Its always comforting to read everyone's comments and suggestions.
Old May 20, 2012 | 11:27 PM
Ballgie's Avatar
Ballgie has a spectacular aura aboutBallgie has a spectacular aura about
I got same problem on my 2000 Boxster. But my question is if change ignition switch. Do I have to replace the new car key? Or use my existing one? Thx.
Old May 21, 2012 | 01:52 AM
911ANIMAL's Avatar
Hi, no reason to change the key. The switch is located "behind" the key. I bought the ignitionswitch for 40$ from Audi in Norway, probably half the price in the States. Same switch for Porsche, Audi and VW.
Here is the DIY that i used: http://www.renntech.org/forums/tutor...with-pictures/
Old May 21, 2012 | 11:35 AM
Ballgie's Avatar
thx for info, but the DIY link need log in to see?
Old May 21, 2012 | 02:53 PM
911ANIMAL's Avatar
Thats correct.
Good site with alot of helpful DIY's
Old May 21, 2012 | 03:53 PM
Gonzo911's Avatar
Gonzo911 is infamous around these parts
Had the same problem here. After you start the car, you can also turn the key back slightly to the left (counter clockwise) and your AC and other accessories should work. This will buy you some time until you can get it fixed.
Old May 21, 2012 | 04:28 PM
invius's Avatar
invius is infamous around these parts
+1 what Gonzo said, move the key slightly to the left, and it will turn the accessories (a/c, etc.,) back on. It is definitely the ignition switch, get the Audi part, it's not very expensive and not too hard to replace from what I hear.
Good luck!
Old May 21, 2012 | 05:47 PM
RobbC's Avatar
RobbC is infamous around these partsRobbC is infamous around these parts
I had to do this to my car and replacing the switch via the DIY posted above worked.
Old Aug 28, 2012 | 06:59 PM
Jnlew's Avatar
Jnlew is infamous around these parts
Ingnition problem
Replaced ignition switch and solved the key issue. Accessories still don't work. No a/c, headlights or wipers. Any suggestions?
Old Aug 28, 2012 | 07:22 PM
rrrruben's Avatar
When it comes to anything electrical, the first fix I attempt is a battery reset. Disconnect the battery for a few minutes. And, hopefully that will remedy your issue. Good luck.
Old Aug 28, 2012 | 10:48 PM
Jnlew's Avatar
Thank you. I will try that first thing tomorrow. Much appreciated!
Old Aug 29, 2012 | 08:42 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Me to!
I had the same problem last week, the key would not go in at all So after exhausting research I found out I had my truck keys
Bad I know...sorry.
Your switch is going bad, easy DYI, cost about $12.
