HELP...groceries stuck in trunk
Old May 9, 2012 | 04:25 PM
Parkcity911's Avatar
Parkcity911 is infamous around these parts
I've got a 2001 996 and my front trunk is not giving in this time. Sometimes I hear a click and sound, sometimes not. But, need to get those fricken groceries out before I have a mess on my hands. Do you think it is the power source or bad release mechanism? Advice please and thanks.
Old May 9, 2012 | 05:18 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
There is a mechanical release cable that can be fished-out from the bumper or wheel well, not sure which. Do a search here, and on Rennlist.com. Good luck!
Old May 9, 2012 | 05:22 PM
djantlive's Avatar
you should have fixed it instead of letting it slide. duh...
since the car starts up fine, i doubt it's a power issue. most likely the switch has failed. visit your dealer. as for the manual release, i think you have to remove the wheel liner. not easy
Old May 9, 2012 | 07:10 PM
wyovino's Avatar
Here is a reply about a similar problem:
There is an emergency cable pull that is located behind the passenger side headlight. With a little effort you can pull back the wheel liner on that side and get to the cable. Some folks (like me) have relocated their cable so it can be reached by popping off the front bumper tow plug. To do this relocation you have to take the front bumper off (or already have it off... like to clean the radiators, or install the 3rd radiator, etc.)
Old May 10, 2012 | 10:18 AM
When I got home after running some more errands it just opened as if nothing ever was wrong. Arghh. Anyway, yes...probably bad switch. Glad it did not happen at the airport! I'm ordering a switch ASAP. Oh, and thanks for the note on fixing before letting it slide...HA. Sounds like something I'd say to my wife...touche'.
Old Sep 6, 2012 | 07:50 AM
Still glitching
Had the front latch replaced and this sucker is still glitching....only opens when it wants to. Any ideas on what else it may be besides the front latch?
Old Sep 6, 2012 | 08:05 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Brother, take it to your dealer and have it fixed. Very simple technology which I'm sure they will fix quickly.
Old Sep 6, 2012 | 08:17 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
IMO it would seem like you have a short somewhere. Just take some time and visit the stealer or an indy. Should be an easy fix.
Old Sep 6, 2012 | 10:45 AM
zeeeeeee's Avatar
zeeeeeee is infamous around these parts
Are the groceries okay?
Old Sep 6, 2012 | 11:25 AM
LOL....the groceries were saved.
Yes, must be a short, but where to start. The dealer did install the trunk switch and said it worked flawlessly when tested. I believe them as this thing has a mind/ timing of its own. Very strange. Anyway, I'll keep you all posted, but until this thing is fixed I won't be putting ice cream up front!
Old Sep 6, 2012 | 04:02 PM
Slopeslider2's Avatar
Slopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura aboutSlopeslider2 has a spectacular aura about
You need to check the solenoid. Mine would sporadically stop working. Seemed to be related to the heat. Once it sat for awhile it would pop open. It located in the Frunk on the drIvers side under the carpet. It's was a 5 min job to replace. Took care of my problem.
Old Sep 6, 2012 | 04:53 PM
That is exactly like mine. Popped right open this AM when it was cool. Thank you SOOO much and that is another reason these forums are great. Who knew? Obviously no one else mentioned this. Thanks and good work.
Old Sep 6, 2012 | 04:56 PM
Glad to help. Good luck.
Glasgo
Nov 30, 2015 02:37 PM
sdg1871
Nov 22, 2015 07:27 PM
jdubbya
Sep 28, 2015 04:58 PM
Goonie
Sep 25, 2015 06:34 PM
lokmeup
Sep 9, 2015 09:24 PM
