Oil leak
Old Jul 23, 2012 | 12:33 PM
nottoshabi's Avatar
nottoshabi is infamous around these parts
Oil leak
I noticed over the weekend I have an oil leak on my 2000 carrera. There is a slightly smaller size then a silver dollar oil stain on the floor. Its quite small but its definably there. I looked under the car and around the engine to see where its coming from. The engine looks clean from the top and around the side from what I can see with a flash light. Where I noticed the oil to be dripping is on the driver side on the edge of the motor it look like its coming from the valve cover. It only leaks when I drive it, if the car sits it does not leak at all. How much does this run to fix in a shop and do I need to brace my self for other problems like the spark plug casing or anything like that?
Also should I change this right away or can I wait for my scheduled maintenance in about 4 months?
Old Jul 23, 2012 | 12:40 PM
jzarrabi's Avatar
jzarrabi has a spectacular aura aboutjzarrabi has a spectacular aura aboutjzarrabi has a spectacular aura about
Personally, I would have it looked at. While the answer might be obvious, if it isn't what you think it is at first, it could end up causing alot more damage
Old Jul 23, 2012 | 02:23 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Well, if it were me I'd do the maintainance now and have it checked. Since it's only a small amount it might be just a seal but, it may be leaking worse when driving because thesystem is under pressure, something to consider.
Old Jul 23, 2012 | 02:56 PM
nottoshabi's Avatar
@Fla996TT That is the same think I'm thinking about is just I have been getting quotes from 700 to 3K for this job alone. This plus maintenance I might be in a world of hurt.
Plus on my old non German cars, a valve cover seal change is a breeze. I'm totally ok with a pro duing the work I just dont wan to get shafted. Or better yet have a ground to argue with. Most mechanics discuss mechanical work like we have no idea what a wrench is.
Old Jul 23, 2012 | 05:43 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
It is probably your spark plug tubes. I had the same problem last year. It's not a bad job to do yourself.
Old Jul 23, 2012 | 06:16 PM
nottoshabi's Avatar
Thanks J. My scheduled maintenance is coming up so I think I'm going to get leak issue taken care of then. Since they need to get in that area of the engine anyway.
Old Jul 23, 2012 | 06:41 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
The cam covers seldom leak, it is usually a spark plug tube, a cam advance solenoid seal or some other source. The is no gasket to fail with the cam covers, the seal directly to the head with Dreibond.
Old Jul 23, 2012 | 09:39 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
How can you be getting prices on a leak which has not yet been diagnosed? I would take in to your dealer for service and have it inspected while it's in. You'll get your report.
Old Jul 24, 2012 | 12:14 PM
nottoshabi's Avatar
@denversteve What? Did you not know I'm the diagnosis master. Lol. Yore right steve I'm going to make an appointment and get it checked out.
Old Jul 30, 2012 | 11:55 AM
jasonradner's Avatar
jasonradner is infamous around these parts
They Leak!!
The valve covers are common to leak!...mine were done 4 months ago at the wack of $850.00. If not the covers then yes to the spark plug tubes or another common spot is the oil sending unit if on the passenger side.
Wheeler
Sep 22, 2015 08:02 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
Lucid Moment
Sep 12, 2015 01:12 PM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
ricks234
Sep 10, 2015 12:51 PM
