Temperature gauge is blinking red. Temp is at around 180-190 (normal temp)
Old Aug 22, 2012 | 04:25 PM
Black_911's Avatar
Black_911 has a spectacular aura aboutBlack_911 has a spectacular aura aboutBlack_911 has a spectacular aura about
What I did so far.....
- Topped of coolant
- Burped the coolant
- Check the 2 radiator fans (both works)
- Check the engine blower fan (works with bypass connection) Do not know when it should turn on. Does it turn on with the front fans?
It started happening after I got my car from Flintworks shop performed a cam actuator repair which required them to flush the coolant.
Is it drivable if blinking?
What else can cause this problem?
Old Aug 22, 2012 | 06:39 PM
bornrich's Avatar
bornrich is infamous around these parts
I would call Flintworks and ask them as they did the initial work. I have used them for several repairs to my 99 996 and they have stood behind all of their work for me.
Old Aug 22, 2012 | 06:47 PM
Black_911's Avatar
Will do. Thanks!
Old Aug 22, 2012 | 11:03 PM
150shot's Avatar
150shot is infamous around these parts
Let us know what this is, i've had it once in a drive thru through , but im pretty sure my compartment fan error message came up but , then never came back later..
Old Aug 23, 2012 | 03:14 AM
Black_911's Avatar
You said that when your temp gauge was blinking but it was in the normal temp, your compartment fan error came on?
So could this be a compartment fan or engine blower fan?
Old Aug 23, 2012 | 08:34 AM
Detoxx's Avatar
Detoxx is infamous around these parts
Don't drive it and call flintworks as suggested
Old Aug 23, 2012 | 06:39 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Are you sure that's which light is blinking? Check you manual if you haven't as there are several indicators with the one light. One indicates temperature problem (which it doesn't sound like you had) one is coolant level, one is oil level. I believe that is it. Either way, I've thought it was oil level once and it was coolant level. I had to trouble shoot it with the manual.
Old Aug 23, 2012 | 07:33 PM
Black_911's Avatar
Here's a picture. (not my actual cluster)
Blue signifies my temperature while driving.
Green signifies where it blinks. (not steady)
Old Aug 23, 2012 | 10:11 PM
CDLVancouver's Avatar
CDLVancouver is infamous around these parts
thats where mine is pegged...takes a while to get there then stays there. but i dont get a blinking
Old Aug 23, 2012 | 10:37 PM
Blue signifies my temperature while driving. Green signifies where it blinks. (not steady)
Again, go to your manual. The illumination of that light has several different meanings. Once you've read the manual section you will know the 3 things to check.
Old Aug 23, 2012 | 10:48 PM
rrrruben's Avatar
rrrruben is infamous around these parts
Your gauge appears normal (~180*). I checked my owner's manual: If the coolant temperature is too high, the warning light comes on... If the coolant level is too low, the warning light comes on...In addition, this warning light flashes to indicate a fault in the engine compartment blower fan. I believe the latter is the culprit. Good luck.
Old Aug 24, 2012 | 06:11 AM
trenddy996's Avatar
trenddy996 is infamous around these parts
There is a temp sensor located on the passenger side intake manifold. If it fell off and is laying in the engine it will set it off bc it is seeing high temps. That will set that light off. Could also be a bad sensor causing it to get set off.
Old Aug 27, 2012 | 04:14 AM
Black_911's Avatar
Where would that sensor be exactly?
Old Aug 27, 2012 | 07:31 AM
stephan_porsche's Avatar
stephan_porsche is infamous around these parts
Could be a faulty coolant level sensor also. Check the connection.
Old Aug 27, 2012 | 09:54 PM
Black_911's Avatar
Well guys. To go to Flintworks is about 70 miles/1 hr trip. Is it safe to drive it there? I mean my temp stays at 180-190 the whole time. No sign of over heating. I don't wanna deal with towing.
