oil indicator fail
Old Jan 7, 2013 | 12:51 PM
spenat's Avatar
spenat is infamous around these parts
oil indicator fail
over the past week or so I have had the following happen 2 x. About 2-3 minutes after starting the car and driving away the warning pops up saying oil indicator fail, the oil gauge drops to 0, after about 10 seconds the the warning goes off and the gauge goes back to normal. usually on colder mornings.
ideas?
Old Jan 7, 2013 | 01:30 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Fairly common, oil pressure sending unit, simple fix. First off pull the wires and clean the terminals, this could fix the problem, if not replace the sender unit. Circled in pic.
Old Jan 7, 2013 | 04:55 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
Hey FLA - how hard is it to get to that part, pull it off, clean it, and stick it back on?
Old Jan 7, 2013 | 06:38 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
There are several threads on this here and on Rennlist. Search is you friend.
Old Jan 8, 2013 | 06:15 AM
FLA996TT's Avatar
The unit is located on the forward right side of the engine just under the AC hoses. You'll need a 19mm cresent wrench to remove the sensor, but the terminals have a small nut but you don't have to remove them, as you can see in pic 2 the wires should just "unplug.". Use contact cleaner from Radio Shack or Ace etc.. You will need a good light as well, what makes this a PITA is there is very little room to work (who'da thought). Just go slow and steady. You may have to work by feel alone at times. If you feel industrious, spend the $66 and just change the unit.
I hope this helps.
Old Jan 8, 2013 | 09:32 AM
ECS Tuning - Porsche's Avatar
We offer two different brands of the oil pressure switch. As FLA996TT it isn't really that hard to do but, I would advise getting a new one. Click Here for more information.
Old Jan 8, 2013 | 11:46 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
As Dharn55 says, do a search...several procedures details replacement of this part can be found.
The one I used (which is, I think, the one Dharn55 wrote!) is to jack up the right rear of the car and access the sender unit from underneath using a crow's foot on a ratchet extention. You'll spend far more time jacking up the car than removing/installing the sender, and you'll lose far less meat from your knuckles, that way.
Good luck.
Old Jan 8, 2013 | 12:59 PM
spenat's Avatar
thanks everyone
PV=nRT.
Sep 9, 2022 06:06 PM
Saint Ari
Jan 17, 2022 09:22 PM
ant_8u
Apr 10, 2016 11:42 AM
as4driver
Sep 10, 2015 09:32 AM
oo7
Sep 10, 2015 08:08 AM
