Rough idle blinking temp light.
Old Feb 17, 2013 | 03:30 PM
nottoshabi's Avatar
nottoshabi is infamous around these parts
Hey guys i just got in the car and started the engine after grabbing lunch and the temp light started blinking. The temp is normal just the light is blinking and i noticed that it idles a little rough when i stop at a light. Any ideas?
Old Feb 17, 2013 | 04:00 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Check you coolant reservoir tank to see if the level is low, this is what causes the blinking light, and if the coolant is contaminated. Hopefully it is just low coolant, which may mean a leaking tanks, a bad cap or a leak elsewhere.
Old Feb 17, 2013 | 04:04 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
The frequency of the flashing light is part of the diagnosis.
Here is the long explanation on the flashing coolant light.
"Four functions of the coolant warning light:
1. Engine coolant level too low -- light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high -- light is lit; pointer on the right
4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right
Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
Old Feb 17, 2013 | 04:36 PM
nottoshabi's Avatar
Pulled the cap off. There is no more collant in it, well what ever is there it looks like a milk shake. Im going to get it towed to the shop.
Has any one had this before? Do i have to rebuild the engine? I have had this before on a Honda and a land rover after i replaced the head gasket it ran fine. Would this work the same way?
Old Feb 18, 2013 | 07:06 AM
FLA996TT's Avatar
Oil in the coolant, could be the air oil seperator bad oil cooler seal, or yes a blown/cracked head gasket. One way to tell is to pull the dipstick, if the oil there is clean (no innermix) than the problem is not to serious, if it's there as well look to the heads or oil cooler gasket.
Old Feb 18, 2013 | 11:21 AM
nottoshabi's Avatar
Took it to the shop this morning. Got it on the lift drained the oil out. It had a good percentage of radiator fluid in there. After draining the oil the mechanic told me that in order for that much mixture to be in the oil, I have had to been driving with the intermix for a while. The car did not give any sings of over heating or that it had a problem until the light started blinking. I will find out more details after more tests.
Old Feb 18, 2013 | 04:46 PM
nottoshabi's Avatar
Got back form the mechanic it is a leaking head gasket. They drained all the oil and flushed out the radiator refilled fluids back drove it around for 20 minutes and it started to mix again. This is not going to be cheap. Im looking at around 5-7k for the fix. Man this sucks.
Old Feb 18, 2013 | 05:39 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
Just curious what year and how many miles are on your car?
Old Feb 18, 2013 | 05:52 PM
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
That sucks
that sucks. Is this something that can be avoided or is it just a wear and tear type issue that happens sometimes?
Old Feb 18, 2013 | 06:26 PM
nottoshabi's Avatar
2000 102,685 miles. Car ran like a champ till this incident. It totally sucks, I don't know if you can avoid stuff like this even if you constantly check fluids and listen to the engine. When I talked to the mechanic he told me the ante freeze was low. Which made it over heat and that warped the head gasket. The heat gauge never ever passed 0 on the 180 mark that I know for sure. But over time and miles it went.
I know on my old rover and mustang that happen when the car over heated like it was hot and really over heated for the head gasket to go. Actually on the rover the gasket went at 135k but the car over heated first then it went. ON the Porsche there were no sighs of over heating ever it ran fine. I should of know to check the fluids more often. I was at 7500 miles to my 10k service and since the car ran great I did not think to check. Next time I know.
Old Feb 18, 2013 | 08:27 PM
white out's Avatar
white out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to behold
It's not necessarily overheat that can kill a head gasket. Normal heat cycles and time can cause it.
Have you thought about switching over to Cometic head gaskets?
This is a good time for a new clutch, IMS bearing, front & rear main seals, timing guides, AOS, spark plugs, etc. All of those items are going to be much easier to access while the engine is out.
Old Feb 19, 2013 | 12:54 AM
nottoshabi's Avatar
Yes agreed all in the works already. Ims and clutch have 30k miles on them, but will defiantly change if needed. The shop is pretty good and honest so if anything needs updating they will let me know.
Old Feb 19, 2013 | 08:20 AM
SoCal GT3's Avatar
SoCal GT3 is infamous around these parts
Sorry to hear what happened. I hope the car get fixed in no time. I am local to you, where are you planning to have the engine work done at?
Old Feb 19, 2013 | 08:49 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
If there is no fuild then the temp gauge can't measure anything. I doubt it was that low. Could also be a cracked head. I know Dharn55 know all about that.
Old Jan 16, 2017 | 08:14 AM
Alexdamann's Avatar
Alexdamann is infamous around these parts
Intermix milkshake problem
Hopefully your intermix problem is caused solely by a faulty AOS. However, you may wish to run a web search on the Porsche 996 D CHUNK problem. Cylinder head problems are uncommon for the 996. D Chunk happens more frequently. Best wishes that you need only an air oil separator.
