cab top help ?
Old Oct 30, 2013 | 07:59 AM
jacabean's Avatar
jacabean is infamous around these parts
cab top help ?
I have a very annoying rattle in my top at the windshield . The top actually slaps the window frame on rough roads. the roof latches ok . It is the centering journals on each end that are very loose . From searching , i found that they had a plastic part that was like a bushing to make everything tight , my car does not have this part in place . they are no longer made and cost less than a dollar each . They make a replacement part now that are 50 dollars each . I am not sure this will solve my issue . anyone have experience with problem area ?
https://www.6speedonline.com/forums/...1&d=1383141508
Old Nov 4, 2013 | 08:44 PM
Hurdigurdiman's Avatar
Hurdigurdiman is infamous around these parts
I have the 99 C2 cab although right now I have the hard top in place, I am pretty certain that there is a plastic piece in each of the outside slots that accept the hard top. Under that plastic piece is a screw which can come loose and needs to be tightened up for a solid fit. In your case it appears someone has removed that part for some unknown reason or another. You will need that piece to stop the roof from moving. IMHO.
joeyharp
Aug 29, 2016 09:41 PM
BLKMGK
Sep 19, 2015 03:51 PM
Wildcat1212
Sep 5, 2015 05:35 PM
AdamNoone
Sep 3, 2015 04:15 PM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
