Passenger door/window
Old Jun 7, 2014 | 07:00 AM
acmf74's Avatar
acmf74 is infamous around these parts
My passenger door wont close one the first try. It appears that the window doesn't retract enough to release the air in the cabin.
Does the window motor need to be adjusted or do I need a whole new unit for the window?
Thanks!
Old Jun 7, 2014 | 08:37 AM
peteb3's Avatar
peteb3 is infamous around these parts
You could try adjusting
Most likely it's the micro switch in the door handle
Common problem
Search on here or rennlist
Old Jun 7, 2014 | 09:50 AM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
My drivers door just started this! If i pull slightly on the handle I can hear it try. If I push down on glass with door open it will stay down. When I close the door it goes up like normal. All the searching leads me to a bad regulator
Old Jun 7, 2014 | 07:59 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Do what Vantaredoc did. If you get the same result you too will need a new regulator. The window doesn't drop to let air out. It does it to clear the lip on the cabriolet roof.
Old Jun 8, 2014 | 09:50 AM
Dennis C's Avatar
Usually it's a regulator problem if you're able to push the glass down by hand and it raises when you close the door. If not, then it's probably a micro switch problem.
Old Jun 8, 2014 | 12:15 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
I had the same problem a couple of days ago. I just did the what we did with some other cars.
1) Lowered the window and got in the car
2) Rolled up the window keeping my finger pressing down even after it reaches the top. Held it there for 5 seconds. Released button. \
3) Pushed down again the button again and held it for 5 seconds.
Don't know if it was luck or what but It hasn't caused me a problem since. Try that and see what happens. Otherwise its a hardware issue.
00aston
Aug 5, 2023 10:59 PM
Perkman87
Nov 19, 2015 05:31 PM
Vantagelvr
Oct 4, 2015 07:27 AM
Jrox
Sep 29, 2015 12:05 PM
