HELP - Failure Spoiler Control
Old Oct 22, 2005 | 09:16 AM
Captain Tal's Avatar
Captain Tal is infamous around these parts
I need help.
I installed Misha's wing along with the GT2 wiring harness and I am still getting the warning light.
Any ideas?
I have read all the previous threads regarding this issue. I thought I would be avoiding the problem by installing the GT2 harness.
Old Oct 22, 2005 | 10:38 AM
TT Surgeon's Avatar
Tal, been there , done that, got the t shirt.
If you are not using a brake light use harness 996 612 070 51, cost 48$
If you are using a light, 996 612 070 04, cost 100$
This will fix your problem, the other fixes seem a little awkward to me. Good luck, the only other issue I had with the wing was high speed/track instability, fixe4d after adding a TT front lip.
Chris
Old Oct 22, 2005 | 10:46 AM
I am using the 996 612 070 51 part and I am still getting the light. Do I need to temporarily disconnect the battery?
Old Oct 22, 2005 | 10:48 AM
TT Surgeon's Avatar
Check your connections, should not alarm at all, mine didn't. The battery is worth a try.
The ~51 harness is the carrera wing harness, not the GT2 harness, not sure if that makes a difference, pn's are different.
Old Oct 22, 2005 | 11:16 AM
Hmm..that may be it. My dealer ordered the part. I'll check to see if I have the 996 612 070 51 part or if it is the GT2 harness. I thought they were the same.
Old Oct 22, 2005 | 12:04 PM
TT Surgeon's Avatar
If it was more than 50$,it was the wrong one. Porsche always marks up the prices. The ~04 harness is identicle to the C4S aerokit harnes, the ~04 is 100$, add C4S to the name and the price is 354$.
If your connections are not tight, the relay circuit/bypass circuit for the retractable spoiler won't work and your car will think it still has the retractable unit that is failing.
Old Oct 22, 2005 | 03:40 PM
MishaDesigns's Avatar
Tal,
996 612 070 51 is correct wire harnesses that you should use with my GT2M wing.
As Chris mentioned check your connections and if everything is OK with harness itself the light shouldn’t be on. Also try disconnecting the battery if the light was on before you use 51 harnesses.
This is OEM harnesses for fixed wings without the light and nobody had problem with them before.
PV=nRT.
Sep 9, 2022 06:06 PM
Texas1
Sep 20, 2015 09:12 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
