help with master cylinder reservoir replacement
Old Sep 17, 2018 | 03:00 PM
edes300's Avatar
edes300 is infamous around these parts
Hi, need some advice please.
I have a 2003 996 with manual trans. and PSM 110,000 miles. My problems started when my pressure feed line which runs from the master cylinder reservoir to the PSM pump was punctured by a sharp object causing brake fluid to leak. I replaced the part with a new one part number 99635532141 but by accident pulled out the entire fitting that this connects into the master cylinder reservoir. It puled out when I removed the old line. Its a copper fitting with two blue rubber O rings and one of them is torn. Even if they were both intact I'm not sure they would go back in anyways without some type of press to insert the fitting. Do I need to but a whole new master cylinder reservoir? I do expect that I will have to go to the dealer to get the PSM system bleed properly but I could do the rest at home.
Thanks for any help.
Old Sep 25, 2018 | 06:43 PM
edes300's Avatar
anyone out there?
Old Sep 26, 2018 | 11:19 AM
nottoshabi's Avatar
nottoshabi is infamous around these parts
That might be a part that comes together as one. I might be incorrect just thinking out loud here. There is some pressure in those lines. I would recommend taking it out and going to a place that specializes in breaks like a mom and pop shop not a big chain those guys don't care they just want to replace parts and collect money. Tell them the problem and show them the part they might be able to help you out or point you in the right direction. Also have you tried emailing Dave over at pelican parts?
Old Sep 29, 2018 | 03:37 PM
edes300's Avatar
Thanks for the reply back. I ended up buying a new master cylinder resiviour from FCP Euro for 95 dollars. Only took about 20 min to install it, then I bled the brakes with my power bleeder. Breaking is better than ever.
For anyone else in the future. In order to disconnect the PSM line or the Clutch line you should hold a thin wrench up against the grey plastic piece while you pull hard on the line otherwise you risk pulling out the entire fitting like I did.
Old Oct 1, 2018 | 10:54 AM
nottoshabi's Avatar
Thanks for the info. How is the power bleeder? Is it worth the money?
Old Oct 1, 2018 | 11:06 AM
edes300's Avatar
It worked well but I would recommend the more expensive black label version with the cap that swivels so that the hose doesn't tangle up when you twist it on.
Hunter 996
964
Jun 12, 2024 09:52 AM
VIPNiSS
Cayenne 955/957
Feb 13, 2021 08:22 AM
AriS4
Nov 7, 2015 09:29 PM
silvershark
Jan 15, 2011 03:32 PM
Shay2n10
Mar 10, 2009 06:36 AM
