Anti-lock brake question
Old Apr 17, 2006 | 11:40 PM
xx911carreraxx's Avatar
xx911carreraxx is infamous around these parts
What issues would make my antilock brakes go off early? Worn out pads? My antilock seems to go off sooner than it should. Like if someone was to cut in front of me and I would need to step on the brakes a little bit harder, it would start to go off... Doesn't feel very safe. Any input would be appreciated thanks!
Old Apr 18, 2006 | 03:13 AM
djantlive's Avatar
do you flush brake fluid every 2-3 yrs? if not, try this first.
are the tires worn? if so, replace with good tires that match.
abs sensor may be corroded.
are you riding on stock rims or some aftermarket size? oversize rims can cause abs to go off.
Old Apr 18, 2006 | 03:27 AM
I was suspecting the brake fluid. I got the car used about 2 years ago and haven't changed the fluid since, so maybe i'll try that first. Then i'll check the abs sensors... When I bought the car, it had aftermarket wheels on it, 17's on it. Not sure what the stock size was, but I believe the ones on there right now are 17's. Thanks for the info!
Old Apr 18, 2006 | 07:23 AM
testdrv321's Avatar
Auto Cross Expert
testdrv321 is infamous around these parts
ABS looks for the locking of the tire (change in speed verses other tires). If you changed the tires on the car to something with less grip due to cost or design (i.e. snow or all season) it will lock easier and the ABS will come on quicker.
Old Apr 18, 2006 | 02:52 PM
My car has Continentals (225/40/18) in the front and Michelin pilots (265/35/18) in the rear; both have about the same tire wear.
Correction from my earlier post : 18inch rims instead of 17's..
Old Apr 18, 2006 | 02:55 PM
testdrv321's Avatar
Auto Cross Expert
Sizes are good, mixing is bad. The different tires have different friction coefficients which are probably pissing it off. The Conti's are hard compared to the Pilots.
Old Apr 18, 2006 | 03:51 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Conti's should only be used is you are looking to complete in a drifting competition. Traction sucks, and therein is your problem, most likely.
Old Apr 18, 2006 | 04:02 PM
TTKEN's Avatar
TTKEN is infamous around these parts
Talking Tried to mix tires
I tried new cheap rear tires with original cont on the front. Bad deal. The PCM and anti-lock went on all the time, violent on turns at mod speed. Its the type of tires not the brand. Got a lesson from Tires Rack, forgot most of what he said except "DONT MIX TIRES MNFs and you'll be OK". Got new tires for the rear and it was perfect!
02'C4S
Old Apr 18, 2006 | 10:22 PM
Dangit... Now I have to replace the front tires...
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
Sales@RSW
Sep 3, 2015 09:34 AM
rnl
Aug 26, 2015 02:36 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
