Cab Top Problem Question
Old Mar 3, 2004 | 05:43 PM
BartN (TX)'s Avatar
BartN (TX) has a spectacular aura aboutBartN (TX) has a spectacular aura about
For some reason the top no longer will raise or lower using the button inside the car. Every time I press it I get the flashing top light on the dash. The top will work using the key in the door however. I've tried moving the e-brake into all kinds of different positions and triple checked that the engine lid is firmly closed. There are no obstructions that I can see and like I mentioned, the top works perfectly using the key in the door.
Old Mar 5, 2004 | 11:59 AM
Paolo996's Avatar
Paolo996 is infamous around these parts
Have you tried opening up the console and checking the connections.? Sounds dumb, but my 2001 Cab did the same thing. Opened it up and jiggled the wires and made sure they were well connected and it's worked fine since.
Old Mar 5, 2004 | 12:41 PM
PeterC4C's Avatar
PeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud of
If it's a bad connection on the switch, the light should not flash either. the problem should be somewhere else.
Peter
4ocious
Sep 13, 2015 05:00 PM
pshep138
Sep 1, 2015 09:45 AM
991carreradriver
Aug 30, 2015 04:16 PM
gulf gt
Aug 27, 2015 10:27 AM
saline
Aug 19, 2015 12:25 PM
