Slow Startup Problem
Old Mar 4, 2007 | 07:16 PM
Rocky's Avatar
Rocky is infamous around these parts
Hello all. Haven't had any problems with my car until now. Not a daily driver, but I've recently come across a slight problem. At around 28k miles, my car now seems to be slowly starting up at cold or warmed up. Just seems like there's not enough juice going through the car. Could it be the battery, spark plugs or something else? Just thought I'd get some info from you guys before I bring it in. Thanks in advance.
Old Mar 4, 2007 | 07:24 PM
demosan's Avatar
demosan is infamous around these parts
Rocky,
If this is the original battery in your MY02, it is the battery going south on you. I have an 02 as well and had a similar experience and replaced battery and all is well.
Demosan
Old Mar 4, 2007 | 07:25 PM
Rocky's Avatar
Thanks Demosan. Will give it a try. If anyone has any other advice in the meantime, I'm all ears.
Old Mar 4, 2007 | 08:35 PM
PeterK's Avatar
PeterK is infamous around these parts
Put it on a battery tender. Not a DD + older battery = not enough amps goes out.
Old Mar 6, 2007 | 11:08 AM
wasuki's Avatar
wasuki is infamous around these parts
yea I think it's the battery, one of my buddies had the same issue after replacing it, it worked out pretty good for him.
Old Mar 6, 2007 | 05:07 PM
Brucem's Avatar
Senior Member
Brucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to allBrucem is a name known to all
I have a similar problem sometimes... after car is warm.. new battery and all... sometimes will crank once...then i have to turn the key off, then back on again... wants to act like battery going dead but just slow to crank
Old Mar 6, 2007 | 06:02 PM
Vik's Avatar
Vik
Vik has a spectacular aura aboutVik has a spectacular aura about
It sounds like its the battery if it hasn't been replaced yet. I replaced my 2003 996 C2 battery at the end of last year. The car was weekend only with 20k miles. This is a simple DIY, which can be found on renntech.org.
996_717
Jan 27, 2022 04:04 AM
Paintballzen
Oct 10, 2020 12:22 PM
hdc4
Bentley
11
Jan 6, 2019 07:17 AM
BLKMGK
Sep 19, 2015 03:51 PM
kensilver
Sep 17, 2015 04:03 PM
