Who has Skid plate/Sump Guard? Overheat Problem?
Old Mar 29, 2004 | 11:47 AM
DavidS 996 C2's Avatar
Senior Member
DavidS 996 C2 is infamous around these parts
I have one on my 02 C2 with PSS-9's and have had no problems.
Old Apr 2, 2004 | 07:04 AM
Jenner's Avatar
Jenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud of
As you can see, I just got my X74 and engine protection plate from Gert.
Does the engine protection plate attach using bolts that are already present? Should I have received some hardware to install it?
Thanks.
Old Apr 2, 2004 | 07:10 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
It uses existing hardware.
Old Apr 2, 2004 | 07:11 AM
Arnie's Avatar
Arnie is infamous around these parts
You guys are confusing this with the 993. The 993 engine tray is for aerodynamic puposes and is plastic. It has been shown to cause the engine to run hotter. The whole underside is covered on the 993. So the plastic tray is recommended to be removed. This has no impact on the 996 sump guard.
Arnie
Old Apr 2, 2004 | 07:44 PM
pieball's Avatar
pieball is infamous around these parts
I just checked mine, sure enough, it had a couple of scuffs on it. Cheap insurance when you're trying to get some air over railroad tracks! Never had a overheating problem either FWIW.
Samidad
Dec 13, 2019 01:02 PM
kchu221
Oct 2, 2015 10:39 AM
gadgetman
Sep 10, 2015 03:29 PM
