Hardware Radar from upper control area?
Old May 11, 2007 | 05:10 PM
KaamaCat's Avatar
KaamaCat has a spectacular aura aboutKaamaCat has a spectacular aura aboutKaamaCat has a spectacular aura about
Think I'm going to hardware my radar from the top, and before I attempt to "pull" off the cover that houses the dome switchs/moonroof....etc, can anyone recomment the correct way to do it. (like a Bently manual would have instructions for)
Mine is an 04'
Old May 11, 2007 | 05:19 PM
951porsche's Avatar
951porsche is infamous around these parts
its pretty straightforward.
Just pull the covers hiding the screws off. remove screws, then you can bring down the overhead lighting console.
Disconnect it and use a meter to find the +12v ign. I don't remember which wire off the top of my head. Find a ground point. Wire it up.
inside there is a cavity big enough to mount the V1 remote kit and wire from it. Pull it between the headliner and body to the side you want to put it on.
reassemble and you'll be set.
Good luck!
Old May 11, 2007 | 07:22 PM
KaamaCat's Avatar
Excellent, and thanks!
Old May 12, 2007 | 10:26 AM
UCrazyKid's Avatar
UCrazyKid is infamous around these partsUCrazyKid is infamous around these parts
I would recommend just running the wire down from the top along the headliner and A pillar to the fuse box. Not hard to do and in my experience (5 cars) its stay in there nice and tight.
That way you can easily wire it into an ignition switched outlet and have it on a fuse.
AA
Old May 12, 2007 | 10:34 AM
whatever's Avatar
whatever is infamous around these parts
Old May 12, 2007 | 04:26 PM
KaamaCat's Avatar
Good point. That way I can also have a in-line fuse in there for easier access should it ever need to be changed.
Old May 14, 2007 | 05:43 PM
mountainC4's Avatar
mountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to beholdmountainC4 is a splendid one to behold
one more question
How did you get the wires to stay in the pillar and head liner? seems I have a lot of space and the wire just falls out.
Old May 15, 2007 | 10:49 AM
GForce83's Avatar
GForce83 is infamous around these parts
Originally Posted by whatever
Wait - does this work? I tried to do this in my 996, but it didn't work b/c the circuits are different than a 997. I ended up hardwiring my radar to the telephone jack by the radio.
Old May 15, 2007 | 11:05 AM
UCrazyKid's Avatar
If it is not enough to just tuck it in, what I will do is periodically along the length of the wire is wrap it with black electrical tape to make it thicker and then stuff the wire in.
Old May 15, 2007 | 01:18 PM
mountainC4's Avatar
Thanks that was my guess but seemed a little hokey but should work.
Old May 15, 2007 | 04:48 PM
whatever's Avatar
Not the most logical way, but it works. I grab a bunch of the lint from the lint filter from the dryer. I pick it from the dark cloth load to make sure it's close in color with my dark headliner. I use that to stuff the wires in. Just put enough of it through out the whole length. It's lightweight and it's free. The wire will stay in and you can't see it from the outside. Worked like a charm. good luck!!
Old May 15, 2007 | 05:06 PM
KaamaCat's Avatar
My V1 comes in Wednesday and I plan on doing this Friday....so I'll post some info.
Old May 15, 2007 | 08:24 PM
mountainC4's Avatar
Dude that is funny!!
Dryer lint it is.
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
alevine
Nov 4, 2015 10:05 AM
LiquidElephant
Aug 27, 2015 06:17 PM
