Rear Sitting Lower Than Normal?
Old Aug 22, 2007 | 02:16 PM
Russcan's Avatar
Russcan is infamous around these parts
Hello all, I installed Champion Motorsport springs on my 2001 c2 911. After the install, the rear is sitting a good 1/4 of an inch lower than the front. Is this normal?
Thank You, Russ
Old Aug 22, 2007 | 03:29 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Course not.
If it is normal (for Champion)......that's unacceptable.
If anything......most people with adjustable height suspensions, dial-in some rake (rear to front).......not the other way around.
Old Aug 22, 2007 | 03:35 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Thank You, Russ
What condition are your shocks in? Installing lowering springs on stock shocks is a no no....The shocks will wear much faster, have a much more harsh ride and tend to bottom out prematurely. Think about it, when you lower the car your shocks will then be in a partially compressed state at all times. Also more weight is on the rear so if your shocks are bad, it will sag in the back. For lowering springs you should install a matched set of shortened shocks so you get full shock travel as well...This is why coilovers are so popular, you get a matched set and more adjustability with not that much more cost than springs and shocks....springs only is kinda doing it on the cheap....
Old Aug 22, 2007 | 05:42 PM
Russcan's Avatar
I really never noticed if the car sat lower in the back (pre-springs) or not? I do not think that the spring setup was intended to make the rear lower. I really wanted to know when the car new, was it lower in the back than the front from the factory? Thus by installing the springs, it would have lowered it the same making the rear lower than the front still.
Old Aug 22, 2007 | 05:52 PM
newport996's Avatar
From he factory, the front is higher because of DOT regulations with bumper heights. Lowering springs always lower the front more. Even Porsches sport suspensions lower the front more for this reason. Its a disadvantage aerodynamically to have your front higher as it allows more air under the car and will lift the front end at high speeds instead of pushing down the front.....so Champion lowering springs should lower the front more and thus make it about even if not lower in the front. Which is how they are in Europe.
Old Aug 22, 2007 | 08:20 PM
TheSpeedDemon's Avatar
TheSpeedDemon is infamous around these parts
Dump the spings and get a true lowering suspension.
I had springs in for 3 weeks before I ripped them out and installed the X74. Like newport says, you are compressing the shock/strut with lowering springs and I had a problem at speed when hitting bump the shocks/struts would decompress like normal and the car bounced, very bad and unsafe.
So quit being cheap and get a suspension that lowers and gives you the look and feel that you should have.
Old Aug 22, 2007 | 08:37 PM
joekimdds's Avatar
joekimdds is infamous around these parts
is your car a cab? b/c i've seen the same problem in the past...some springs did not differentiate coupe vs cab and made the cab sag in the rear...
Old Aug 22, 2007 | 08:49 PM
newport996's Avatar
Unfortunately if they are Champion springs, they probably were not cheap....but yes they will Pogo....I have PSS9's and the car is PLANTED...
Old Aug 22, 2007 | 09:15 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
yeah, there's something wrong.. get that checked out by the installer ASAP!
Old Aug 22, 2007 | 09:16 PM
Russcan's Avatar
I do have a Cab. When I bought them, they were listed as Cab springs. Probally some flunky selling of his trash he ended up with. Well, i guess you live and learn. By the way... someone tell me how to post pictures. When I try, it says there is some error. I made sure the file size was not to big. Any help?
Thanks, Russ
Old Aug 22, 2007 | 10:04 PM
angldrkns9's Avatar
Thanks, Russ
its a lot easier to just upload them using www.imageshack.us
and then click on the insert picture and copy and paste the link
Old Aug 22, 2007 | 10:12 PM
Russcan's Avatar
Ok see if it works?
Old Aug 22, 2007 | 10:20 PM
newport996's Avatar
If you click the little box with the mountains and sun in the reply box...then paste the url of the pic the the drop down box....then it comes up in the post....
Old Aug 23, 2007 | 07:04 AM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Its possible that the installer didnt remove the rubber spacers in the front, they are good for a least 1/4" in height. This is how my car came out originally too. When the car was in for the alignment, I had the spacers removed and came out perfect Good luck!
Old Aug 23, 2007 | 07:33 AM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Shocks have absolutely nothing to do with supporting the car. With or without shocks, your car will sit at the same height.
