My 996TT w/PSS9s/aggressive alignment in action...
These are pics from two weeks ago at Summit Point. I was on my street tires with Michelin PS Ribs and running my regular ride height with aggressive camber settings... No bottoming out... For those who think PSS9s are an issue at GT2 ride heights, check these pics...
All of these were pre-grounhog...
Bob Mulligan was riding shotgun!
Mike
Mike
Car was very stable with that configuration... I will be trying out some adjustable spats on the OEM stock spoiler this coming weekend and will report back. Don't know who that guy was, but once I got the bugs worked out between me and the track, I was lapping the field pretty consistantly in that group and was glad to get promoted...
Mike
Mike
I think you should have your car corner balanced. My car's front is a little higher than the rear; as long as the weight distribution is correct and the car drives well, I have no problem with a little height differences.
Mikelly:
Nice ride height!! How did you get the PSS9s to lower at that height? As I remember, there isn't enough thread left on the shock, you should be way below max height on the sleeves. Did you remove the helper springs for the extra lowering?
I know what has been said by others about setups on the PSS9s, but I've always argued that something isn't right with the info... Here's why:
Notice all that thread left on the drivers side rear shock mount???
Here's a pic of the car on level ground with very "street friendly" alignment:
Mike
Mike
Mike
For street use, the OEM setup needs better pads and fluid. Otherwise it's fine. For track use, the OEM setup will be fine, but your tracking expenses will increase due to the rotors. The 6 piston setup with custom rotors (See the brake tech sticky up top) will last so much longer in track use conditions and provide more predictable and reliable braking... Not to mention that in the long run the custom rotors/larger calipers will pay for themselves!
Mike
Mike
I looked for a pic of my fronts but don't see one showing the threads left. I'm pretty sure I'm running out of threads in the front, but the car doesn't "bottom" out or have an overly harsh ride for the settings of the shocks, the ride height, or the sway bars... I do have the helper springs on all four corners.
Mike
Mike
