07' GT3 & 08' TT heavy clutch
Old Oct 11, 2007 | 12:12 AM
IXXI Turbo's Avatar
IXXI Turbo is infamous around these parts
Last week I was @ the dealer in Baton Rouge and got in the GT3 and the new 08 TT and was surprised how heavy the clutch was in both of these cars. And was curious if this was the way they always feel? Or is there some kind of hyd. assist or something like it that would make it easier for daily driving and stop & go traffic?
The TT was much much heavier than the GT3's but both took a fair amount of pressure to depress the pedal. Anyhow I guess I was just surprised how much heavier the pedal felt over the 996 TT's I've been in.
Old Oct 11, 2007 | 01:31 AM
mishref's Avatar
mishref is infamous around these parts
Really? I have found that the TT clutch is softer than the 997S.
Old Oct 11, 2007 | 03:09 AM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
+1, the TT clutch is softer than the 997S and the GT3 clutch is much stiffer than the 997S. Maybe the turbo needed to be started to get hydraulic assist.
Old Oct 11, 2007 | 06:31 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
The turbo has an assist that makes it 10x easier to depress than the Gt3
Old Oct 11, 2007 | 06:34 AM
IXXI Turbo's Avatar
thanks for the replys, so there is an assist.
Old Oct 11, 2007 | 07:52 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Were the cars running? Doesn't the clutch get heavier with each successive press if the engine is off because the assist loses pressure?
Old Oct 11, 2007 | 09:09 AM
Texas911's Avatar
Texas911 is infamous around these parts
Yea the TT clutch is super light compared to even a regular 997, but you get used to it pretty quickly. Wish the brake pedal was stiffer though.
Old Oct 11, 2007 | 07:34 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
+1.............
Old Oct 11, 2007 | 08:03 PM
neijia's Avatar
neijia is infamous around these parts
Did you drive the cars?
Old Oct 11, 2007 | 08:27 PM
IXXI Turbo's Avatar
No I did not drive either of the cars. They were both inside on the showroom floor. I had just done what thousands of others had and depressed the clutch, I guess. And it took some effort. which surprised me. That is why I asked the question. I was figuring that there must be something a little different than just a straight hyd. clutch. Some sort of an assist or whatever.
Old Oct 11, 2007 | 10:06 PM
globalm3's Avatar
globalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond reputeglobalm3 has a reputation beyond repute
i owned a 997s and turbo and i was just like you. when i sat in the turbo in the showroom i hit the clutch and was WTF is this a race clutch?!?! then the sales guy was like hang on started the ***** up and it was amazing how easy and light the clutch was, yes I bought that car I hate getting into the s after driving the turbo its a workout....
Old Oct 11, 2007 | 10:15 PM
iLLM3's Avatar
Exactly, and what happens when you press the clutch a few times when the car is off.. GT3 clutch is WAY heavier then Turbo!
Old Oct 11, 2007 | 10:23 PM
globalm3's Avatar
so its really bad if you hit the clutch when its off?
Old Oct 11, 2007 | 10:25 PM
iLLM3's Avatar
No not at all, it just stiffens up since the assist isnt active/flowing/running/circulating the fluids or whatever it is hah!
My GT2 clutch is always the same feel on or off, my turbo if you pressed it too many times would become rock hard!
Old Oct 11, 2007 | 10:31 PM
2thfixr's Avatar
Yes, the needle bearing in the clutch mechanism will rub against the inlet tube o-ring and ultimately cause a hydraulic fluid leak. Everyone knows that.
Just kidding, obviously I made that up. I believe each successive clutch actuation will deplete the pressure built up for the assist system making it harder and harder to push the clutch pedal in, kind of like a brake pedal. Once you start the engine, the hydraulic assist pressure will be restored and pedal effort will be normal. At least that's my theory.....
EDIT: iLLM3 beat me to it.
