BMC Filter Fitment FYI Between 2007 and 2008
Old Dec 3, 2007 | 02:52 PM
GMP Performance's Avatar
Site Sponsor
We have had some people inquire if there were any differences between the 2007 turbo and the 2008 turbo air filters. Well just to let you guys know they are the same. We had a local 2008 turbo come in this Saturday and purchased a set but had heard that there might be differences but sure enough the ones we had here which were ordered during production of the 2007 models, fit perfect.
Old Dec 3, 2007 | 03:37 PM
cooperlee's Avatar
cooperlee is infamous around these parts
are there actually any performance or airflow gains from these BMC filters?
Old Dec 3, 2007 | 04:02 PM
Site Sponsor
From what I hear they give a couple more HP than the K&N on avg.
Old Dec 8, 2007 | 05:46 PM
charles's Avatar
charles is infamous around these parts
do filters alter induction noise ?
Matt,
i am interested to know if the induction roar is louder or no different to oem TT filters. my fabspeeds are giving me whooshes, as opposed to roars.
thanks, and gooday
Old Dec 10, 2007 | 09:35 AM
Site Sponsor
on the tt you shouldn't get that wooshing sound, I know when you run the K&N you don't get that sound. I know the wooshin sound your talking about though. most people get when you install an open cone filter
Old Dec 10, 2007 | 02:10 PM
charles's Avatar
K&N louder or not ?
Thanks matthew,
will the K&N or BMC give a louder induction sound, or would it NOT make a difference in that direction?
will appreciate your reply.
thanks and gooday.
Old Dec 10, 2007 | 02:35 PM
Site Sponsor
K&N is not louder
Old Dec 10, 2007 | 03:00 PM
charles's Avatar
Thanks, matt.
Old Oct 30, 2008 | 02:23 AM
CorruptedSanity's Avatar
CorruptedSanity is infamous around these parts
How often does the bmc need to be taken out and cleaned?
Old Oct 30, 2008 | 03:01 AM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
K&N dosent have any filter for 997TT yet??
Old Oct 30, 2008 | 04:48 AM
charles's Avatar
BMC in turbo
hi CorruptedSanity
BMC it still looks nice and clean after 7,000 klms in 2008 turbo, so no cleaning needed yet. i'll just play it by sight.
for lintc0532........i have not heard of K&N having one yet.
gooday !
Old Oct 30, 2008 | 05:30 AM
Any disadvantage to changing stock filter?
How hard was it to install? Requires any adjustments or is it plug n play?
Old Oct 30, 2008 | 07:36 AM
jhbrennan's Avatar
Very easy to install - pull straight up on air filter cover - it's attached by two posts that go into the top of the filter element and two posts that fit into grommets in the bottom of the engine compartment. Then take out 4 screws, remove and replace filter element and reverse the process. No adjustments needed.
Old Oct 30, 2008 | 08:16 PM
charles's Avatar
from ....sanity --- Any disadvantage to changing stock filter?
no, none of real importance. make sure u 'oil' it before installation.
are you going to do it now?
regards
Old Oct 31, 2008 | 05:55 AM
jhbrennan's Avatar
regards
Bad advice - the filters come pre-oiled from BMC - don't add any more oil or you may cause problems with the MAF sensor. The only time you "oil" the filter is after you go through the cleaning process.
2lflat4
Nov 18, 2019 05:05 PM
tropicatango
Dec 4, 2015 02:45 PM
pnoob2
Oct 31, 2015 06:34 PM
km90265
Aug 31, 2015 11:00 AM
ritchrwi
Aug 21, 2015 04:36 PM
