where to order Rear Axle differential lock?
Old Dec 11, 2007 | 10:49 AM
QTR TT's Avatar
QTR TT is infamous around these parts
my TT didn't come with the diff lock option when i bought it. I called the Porsche service Center in Qatar and i was told that they cannot order that part. they told me that it can only be ordered as an option on new cars. does this make sense?
and does any company make this part other than porsche? maybe Techart etc..
Thanks alot
Old Dec 11, 2007 | 11:12 AM
c2mojo's Avatar
c2mojo is infamous around these parts
Quaife, maybe
Old Dec 11, 2007 | 12:51 PM
TT Surgeon's Avatar
Yes, to retrofit the LSD, the cost would be prohibitive, imo (over 10k).
Old Dec 11, 2007 | 02:42 PM
jhbrennan's Avatar
Less than $2K for the Quaife LSD so if it can be done I imagine it will be considerably less than $10K.
Old Dec 11, 2007 | 02:48 PM
jhbrennan's Avatar
Old Dec 13, 2007 | 04:59 AM
QTR TT's Avatar
thanks alot guys. I'll look into getting a Quaife LSD. Will it make a huge difference in handling? or should i get sticky tyres for track days instead?
Old Dec 13, 2007 | 05:56 AM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
It depends how serious of a track driver/racer you are.
The LSD will deff help on long corners where traction is needed.
I would just some slicks 1st. Your still going to need em' anyways.
Old Dec 13, 2007 | 06:06 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
I bet to replace an OEM LSD is going to be a lot more than $2K.
Old Dec 13, 2007 | 08:43 AM
TT Surgeon's Avatar
I'm not sure you can use the Q unit in the 997TT platform. Guard Transmissions makes a racing lsd 1888 89 GEARS, but it's a lot more than 2k, also try www.powerhausII .com
they were coming out with a unit, again, a lot more than 2k. Honestly, you'll probably never really need it, just get some good rubber and don't worry about it would be my advice.
Old Dec 14, 2007 | 01:51 PM
QTR TT's Avatar
i guess i'll go with some sticky tires and put the LSD money towards some performance parts. i can always make up the lost corner times in the straights
Old Dec 16, 2007 | 12:57 PM
NeoMatrix's Avatar
NeoMatrix is infamous around these parts
Originally Posted by c2mojo
Quaife, maybe
You should read up on the differences between torque biasing (Quaife) differentials, and limited slip differentials (LSD). The Feb. 2001 Issue (starting at page 10) of the Porsche Owner's Club Magazine has a great article....
http://www.porscheownersclub.com/pdf/2001/february.PDF
I think the thing you want to be most concerned about is that while a Quaife has great characteristics under acceleration, it's characteristics are not as good as a LSD under braking. That is, a Quaife becomes "open" under braking which provides less stability under turn-in conditions, essentially the car feels like it has more oversteer. A LSD will make the car feel much tighter during off throttle turn-in, and you can do much more corner braking. This will probably mean nothing to you unless you track the car.
The article (link above) provides a much better explanation than I can provide here. Good luck.
COBB Tuning
Jan 1, 2025 09:02 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
