Valentine 1 problem
Old Dec 22, 2007 | 04:10 PM
alpha nsx's Avatar
alpha nsx is infamous around these parts
Valentine 1 problem
Just wanted to ask you guys a question, I've recently been purchased a 911 turbo cab and wanted to use my valentine 1 in the vehicle. But when I plugged the power source to the cigarette adapter, my V1 did not power up..... Can someone tell me what might be the problem? Thanks in advance.
Old Dec 22, 2007 | 04:31 PM
Jeremy's Avatar
Will Party for Food!!!!
Jeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond reputeJeremy has a reputation beyond repute
You did turn the power on (big **** on the front) right?
Old Dec 22, 2007 | 04:32 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
check your cig. plug fuse in your car.
i had the same problem and it was just a blown fuse.
good luck. =)
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
Three possibilities
1. Fuse blew on the V1 lighter plug
2. Fuse blew on the Turbo's lighter plug socket
3. You didn't push it in all the way
Mine is hardwired now but I had no problems using my V1 in my turbo. Try using the aux 12V socket under the dashboard next to the center stack. If it still doesn't work, it's probably the 1A blade fuse on the V1's plug.
Old Jan 3, 2008 | 03:48 PM
alpha nsx's Avatar
It seems like the v1 plug was slightly bigger, so I pushed it in "all the way" an viola! she started up. Thank you for all your feedback.
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
