How often do you need to add engine oil ?
The low engine oil light came on about at 3200 miles on my 997TT, it is about a quart low, dealer said it might consume up to 1 quart every 600 miles, so mine is pretty normal, right ?
Common, yes, but normal I don't know. My TT uses a qt every 1800 miles like clockwork, no drops/no smoke/broke in by the book. My old c4s used about a qt every 800 miles. I think it has a lot to do with the flat 6 design and pooling in the cylindrrs after a hard run, who knows.
My E63 AMG requires a qt every 1000 miles and dealer said it is normal, but my Cayenne S requires nearly no additional engine oil between services (10000 miles) !
7800 miles on my 13 month old 997TT (just did 2nd oil change). i run about a quart every 2000 miles. when i hit the 2nd 2000 miles, i know it's time for an oil change. my 993TT was about the same.
I keep a quart of oil in my front trunk using a $7 dollar oil case from BMW. This is actually from Larry's trunk but I have the same thing in mine. I like the BMW case because it has velcro on the back so the case stays in place.
I find that I have to add oil periodically but I still haven't completely emptied one quart in 14,000 miles of driving.
I added 1 qt. at the 1st 800 miles. I have 2,400 miles on it now and its still FULL. Might need to top off in about ~600 miles.
No usage in first 800 miles - I had dealer change oil at that time and it was overfilled slightly - I siphoned out about 400ml to get it to the right level and haven't used any over the next 2,000 miles.
I wouldn't worry about it...
I've gone thru about 2.5-3 quarts in 4000 miles. Finding mostly that the oil consumption has to do with how I drive the car... After a few long, spirited driving sessions or a day of track time, I notice I lose a "tick" on the meter at most. I top off periodically, and usually do not let the meter drop below 2 ticks.
Interestingly, our Cayenne S sees more stop and go driving, road trips, etc and never seems to lose any oil (ODO at 26K miles, maybe jsut b/c is well broken in?).
Buy a case of Mobile 1 0W-40 for the garage and it will prob last you years.
I tried to explain it to my best knowledge.
996TT is 1 qt in 800mi or so....no big deal...has just gone up to 1200mi...probably going back down. I don't worry. It is what these cars do. Nothing to lose sleep over. Amazing engine. Just amazing.
JB
JB
