Nav-Tv finally debugged
Old Jan 21, 2008 | 04:07 PM
RAY in Pa.'s Avatar
RAY in Pa. is infamous around these parts
My installer contacted me today and informed me that the folks at Nav-Tv resoved the issue with their unit. About half of the time when waking up the head unit it would not recognize the i-pod. The screen would read no cd changer. He claims that the problem is now fixed. This will be my third unit. I told him that my car is covered and on a lift for the winter, I'll change it out in the spring. Hope three's a charm.
Old Jan 21, 2008 | 06:18 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Mine's on my lift and covered also. I'm going to do the PioneerAVIC-D3 when I get around to it.
Old Jan 21, 2008 | 08:52 PM
gretapass's Avatar
gretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond reputegretapass has a reputation beyond repute
I just purchased one to install on my car when it arrives? Is this a common problem?
Old Jan 22, 2008 | 01:26 AM
atomic80's Avatar
greta, he's talking about the Nav-tv iPod interface kit not the Tooki. Two completely separate items. You have the Dension iPod unit so this issue doesn't concern you.
Old Jan 22, 2008 | 02:37 AM
ELMEL's Avatar
ELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud ofELMEL has much to be proud of
Don't know if it's common, but my NAVTV unit is getting ripped out next week and then thrown off the Golden Gate Bridge so it can't come back to haunt me. I'll be replacing it with a mObridge.
Old Jan 22, 2008 | 05:19 AM
RAY in Pa.'s Avatar
Nav-Tv
You might want to try to swap this unit for a new one. They really might have fixed the problem. If the defect described above applies to you.
Old Jan 22, 2008 | 12:35 PM
ELMEL's Avatar
I'm on my third unit. The above defect is not the only one I suffer from. If the mObridge doesn't work, I'll try the updated NAVTV unit. Thanks for the info! Good luck with yours.
Old Jan 22, 2008 | 01:02 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
The Dension seems to be sailing along just fine if you need another option (and yes, I'm willing to make a deal for you).
Old Jan 22, 2008 | 01:14 PM
ELMEL's Avatar
Yeah, you keep saying that. You're probably right. My installer has had problems with Densions though and was using me as a guinea pig for NAVTV, and now mObridge. Yeah, I know, maybe it's my installer. Could be, but I'm gonna give him another chance. Thanks for the offer, Eric.
Old Jan 22, 2008 | 08:57 PM
scuzy's Avatar
scuzy is infamous around these parts
i love the mobridge works great. One minor bug i did find thou is the 160gb Ipod classic with firmware 1.1 caused a issue on my mobridge. I since downgraded to 1.03 firmware and submitted my ticket to mobridge hope they find a fix for this. Besides that it's a great unit.
Old Jan 22, 2008 | 10:42 PM
ELMEL's Avatar
Do you have experience with the NAVTV unit? If so, can you compare? Thanks!
Old Jan 22, 2008 | 10:48 PM
scuzy's Avatar
No i can't say much about Nav-tv unit. The Mobridge was my first unit and it works as advertise so i have no complains. What issues were you having with your nav-tv ?
Old Jan 22, 2008 | 11:05 PM
ELMEL's Avatar
All of the following are intermittent bugs:
  • doesn't recognize iPod at startup, even after disconnect/reconnect and ignition reset
  • PCM freezes with accompanying high pitch tone; all buttons become unresponsive, including volume (which is really lovely while driving on the highway)
  • list view shows wrong list; for example, the system might show that I'm viewing playlists, but it shows me artists instead
There's more, but I can't remember everything.
If the mObridge works, I'll be psyched, especially considering it has a randomize feature (or at least I think it does).
Old Jan 23, 2008 | 06:40 AM
RAY in Pa.'s Avatar
G-G-Bridge
...well I hope your unit can swim
Old Jan 24, 2008 | 01:14 AM
sfguy's Avatar
sfguy is infamous around these parts
Scuzy - what was the issue with the Apple 1.1 firmware that you submitted a ticket to mobridge about?
I also have an iPod classic 160gb, which now has the 1.1 Apple firmware, and a mobridge, and it seems to work fine after the firmware upgrade - at least, on the couple of very short trips I've made since the 1.03-1.1 upgrade.
I also have had no problems with the mobridge, I installed it myself. Never tried the NAV-TV OPiP or the Denison. On a side note, I also have a NAV-TV Tooki (also self installed) that worked fine until recently. It is being replaced - there is a known bad component problem that NAV-TV have posted about on their support board.
