LED Tail Lights on Turbo
Old May 14, 2009 | 12:13 PM
  #61
reymusic's Avatar
reymusic is infamous around these parts
check ur email
Old May 14, 2009 | 12:29 PM
  #62
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Thanks for the info ,
-So if I understand correct i need another module because i only have the one that goes below the drives seat?
-Move pins ( witch module? )
-Go to the dealer PIWIS to reprog?
Old May 14, 2009 | 12:39 PM
  #63
reymusic's Avatar
You need both front and rear modules..
there are 2 pins that needs moving on front module as well. pin B14 to B34 & pin B6 to B21
and a Porsche dealer to activate LEDs on front and rear units.
part 99761851301 is for the front module
part 99761826008 is the rear module
Old May 14, 2009 | 12:53 PM
  #64
luiscarlos's Avatar
Ok will order the other module ...
Where is located the front module?
Old May 14, 2009 | 12:56 PM
  #65
reymusic's Avatar
under the front seat..Techs at Porsche will know what to do once you give them all the info i gave you.
Old May 14, 2009 | 01:12 PM
  #66
luiscarlos's Avatar
The one I have is now installed under the drivers seat I think that is the rear and the part number is 99761826008 so the front where can i find it?
Old May 14, 2009 | 01:16 PM
  #67
reymusic's Avatar
call suncoast
<ADDRESS>5005 S. Tamiami Trail</ADDRESS><ADDRESS>Sarasota, FL 34231</ADDRESS><ADDRESS>941-923-1700</ADDRESS> ask for Ric.....Do you have the warning light on the dash panel?
Old May 14, 2009 | 01:20 PM
  #68
luiscarlos's Avatar
Old May 14, 2009 | 01:24 PM
  #69
reymusic's Avatar
anytime ,let me know what they tell you at suncoast..
Old May 14, 2009 | 01:54 PM
  #70
AquaGT2's Avatar
AquaGT2 is infamous around these parts
the new tail light looks great, a big improvment.
Old May 18, 2009 | 09:21 PM
  #71
grawe's Avatar
grawe is infamous around these parts
I think they look great! Didn't think I would.
Old May 19, 2009 | 01:54 AM
  #72
Green Turbo's Avatar
Green Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to behold
Well I finally got them working in my 996 TT conversion
Final pictures here
https://www.6speedonline.com/forums/...il-upgrad.html
Old May 19, 2009 | 10:48 AM
  #73
reymusic's Avatar
what set up did u use on the 996TT to make them work?
Old Aug 13, 2009 | 08:56 AM
  #74
slammedM's Avatar
slammedM is infamous around these parts
that looks amazing!
wow
Old Dec 17, 2009 | 02:28 PM
  #75
dnorouzi's Avatar
dnorouzi is infamous around these parts
i would greatly appreciate it if you could point me to the wiring diagram. I am doing the same conversion on my 2008 997 twin turbo. many thanks in advance.
