LED Tail Lights on Turbo
I have gone through the LED tail light modification on my 2008 Turbo. I replaced the front LED module with part number 99761851301.The rear LED module was already in the car. I moved two of the pins (pin B14 to B34 & pin B6 to B21) as suggested by some of the posters here.
The modules were programmed by the local Porsche dealer. All of the lights are properly functioning. However, he could not purge the fault code appearing on the dash. My thinking is that the pins probably should not have been moved.
Any help would be appreciated.
call a.i design one of the board sponsors, they will hook you up....914.779.9000 (ny) ask for todd tell them RV sent you...those are my guys...
slicky rick
Oct 19, 2019 02:05 PM
