Clear Bulbs that glow 'yellow' ... Where?
Old Aug 21, 2008 | 11:28 PM
SaintlySins's Avatar
SaintlySins has a spectacular aura aboutSaintlySins has a spectacular aura about
I've got the clear sidemarkers going in ... but I'm not crazy about seeing the obvious yellow bulb through the lens. I remember reading about place to get a clear or white bulb that when activated, glowed yellow.
Where/who's got 'em?
Thanks in advance,
Old Aug 21, 2008 | 11:30 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
i'm pretty sure it starts with an H. it's on the tip of my tongue and i can't think of it! i'll ask my buddy tomorrow and find out. hopefully by then, someone will already have an answer for you. =)
Old Aug 22, 2008 | 12:42 AM
ChromeHearts's Avatar
ChromeHearts is infamous around these parts
HELLA makes yellow bulbs. Most of the major bulb manufacturers do. I would also recommend going with LED bulbs. They are clear and when activated can emit different light spectra, they last longer, and use less voltage than traditional bulbs. PIAA also makes a light you are looking for.
Old Aug 22, 2008 | 12:56 AM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
i got mine from this site there not yellow when lit up tho http://www.stealthauto.com/Departmen...lth-Bulbs.aspx
Old Aug 22, 2008 | 01:30 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
What I've done is just remove the bulbs.
Old Aug 22, 2008 | 01:42 AM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
I am not sure if these will work, but I have had good luck with Hoen for Audi applications.
http://www.hoen-usa.com/cr.htm
Old Aug 22, 2008 | 07:43 AM
Alcyon's Avatar
Alcyon has a spectacular aura aboutAlcyon has a spectacular aura about
Philips Silvervision
Old Aug 22, 2008 | 08:35 AM
jjtoma's Avatar
jjtoma is infamous around these parts
Thank you for the link.
quote=melsta;2007055]i got mine from this site there not yellow when lit up tho http://www.stealthauto.com/Departmen...lth-Bulbs.aspx[/quote]
Old Aug 22, 2008 | 10:06 AM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Stealth Bulbs
Which stealth bulb do I order for my side markers (2008 997TT)??
Mike
Old Aug 22, 2008 | 03:26 PM
gmoney's Avatar
Hoen 'Chromiums'
www.hoen-usa.com/cr.htm best ones yet.
fitment is the w5w, hides away, glows nice and yellow.
Old Aug 22, 2008 | 04:37 PM
Thanks for the help everyone, but G-Money comes through with the site AND the right fitment type.
Who could ask for more?!
Great news, they have 'em in stock!
You're the best!
Old Aug 22, 2008 | 05:05 PM
sparkhill's Avatar
You may as well go ahead and pick up a set of the Hoen XenonMatch fog lights while you are at it.
http://www.hoen-usa.com/fog.htm
Old Aug 22, 2008 | 05:23 PM
I saw those on the site! They do make the car look contiguous. Thanks for sharing the pict's. I'll be ordering them too. "JMLA" gave me a great site on anther post that sells all kinds of bulbs. Here's the link: http://autolumination.com/1156_1157.htm
This site gives a LOT of options and alternatives. Thanks JMLA.
Old Aug 22, 2008 | 05:35 PM
sparkhill's Avatar
One more thing all the coated bulbs run hotter than stock... the silver coated bulbs are hotter than the sun. Be careful replacing any bulbs that are on for extended periods of time with coated bulbs.
I have always been fine with the Hoen xenonmatch fogs, but several RS4 owners melted their housings and or bulb sockets when they swapped out their day-time running lights for silver coated ones.
Old Aug 22, 2008 | 05:36 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Be careful with some of these bulbs and do some searches on 6speed for other threads concerning this subject. Some of them burn very hot and have actually melted the housings.
