FYI for "higher" mileage and/or modified 997 turbos
Old Mar 23, 2009 | 03:29 PM
  #31
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
so whats the best brand of spark plugs u suggest?
Old Mar 23, 2009 | 05:04 PM
  #32
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
oem twinturbo Bosch FR6 LDC or Denso IK20, for modified 996tt engine Bosch FR5 LDC or Denso IK 22, if you your tune is over 1,3 boost, speak with your tuner he knows what plugs are recommend for his engine (i think over 1,3bar boost it is time for FR4 DP).........if you like to hold your plugs for long time use the Bosch FR LDC type....but the best of all is ask your tuner ore use on oem engine the oem plugs
Old Mar 24, 2009 | 07:12 PM
  #33
yalmutawa's Avatar
oem twinturbo Bosch FR6 LDC or Denso IK20, for modified 996tt engine Bosch FR5 LDC or Denso IK 22, if you your tune is over 1,3 boost, speak with your tuner he knows what plugs are recommend for his engine (i think over 1,3bar boost it is time for FR4 DP).........if you like to hold your plugs for long time use the Bosch FR LDC type....but the best of all is ask your tuner ore use on oem engine the oem plugs<!-- google_ad_section_end --> <!-- / message --> <!-- sig --> _________________
thanks bro
Old May 18, 2009 | 05:14 AM
  #34
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
What would be the best spark plugs for a 997 tt with exhaust, ECU, I/Cs, upgraded VTGs,?
Old May 18, 2009 | 09:30 PM
  #35
Kafka997's Avatar
Kafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond repute
Plugs
I just drove from Canada to San Diego with the AWE 620 kit (yahoo!) and had the local dealer change my plugs as part of my 20K mile maintenance. The plug change (installed platinum OEM 999-170-90 plugs as recommended by my tuner and AWE re GIAC software configs) cost $US 820 (parts but most is labor - it is a big job for pros).
I was hoping it would make me a better driver, but sadly not .
K.
Old Jun 21, 2009 | 09:58 AM
  #36
milou's Avatar
Does anyone know which spark plugs will be best for a 997 turbo with an 700kit? Is it a good idea to close down the gap a little?
thx
Old Jun 21, 2009 | 10:19 AM
  #37
Kafka997's Avatar
I would check with your tuner and company that makes your 700 kit for sure. I had done some research and thought it would be a good idea to put in some plugs that ran cooler. My tuner and AWE were FIRM that I should use OEM plugs as GIAC software is designed for these plugs. Given the cost for replacing them it's a good idea to get the right ones. Keep us posted.
K.
Old Jun 21, 2009 | 11:09 AM
  #38
Alcyon's Avatar
Alcyon has a spectacular aura aboutAlcyon has a spectacular aura about
Ruf Germany for my 550 kit = Beru Ultra 14 FR-6-LDU. GOOD.
by mistake I change to Bosch platin FR6DPP332 = BAAD
Old Jun 22, 2009 | 01:06 PM
  #39
Nico's Avatar
Nico is infamous around these partsNico is infamous around these parts
ok, so after being confused from all the spark plugs mentioned in this thread, can somebody give me the part number for the STOCK plugs? (my car is stock but im at 25k miles). thanks.
Old Jun 22, 2009 | 01:35 PM
  #40
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
It is very simple, ask your dealer when you are doing the service to change them, you don't have to know the part #
Old Jun 23, 2009 | 12:13 AM
  #41
milou's Avatar
I don't know the Porsche part number but i know the brand and the model,
Bosch FR6DPP332
Old Jun 23, 2009 | 01:51 AM
  #42
Nico's Avatar
Bosch FR6DPP332
appreciate it
Old Jun 23, 2009 | 09:44 AM
  #43
milou's Avatar
appreciate it
my pleasure
Old Jan 17, 2013 | 06:52 AM
  #44
G911's Avatar
G911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of light
If it help to somebody
High performance plugs, for tuned Porsche 997 Turbos
The following High performance plugs, for tuned 997 Turbos are recommended:
Best reccomended plugs are the: PK20PR-P8 Denso. Close the gap to .025" for higherboost levels.
The NGK equivalent of stock number 2667 of BKR7EIX is also recomended and used in many of the high horse power Porsche 997 Turbos. The Denso also works well.
Ruf apparently run the "Beru Ultra 14 FR-6-LDU" plugs on their 550 Rturbo.
Stock OEM for the 997 Turbo being the Bosch FR6DPP332 spark plugs.
For Turbo's running under 650hp (crank), OEM plugs may be used and life expectancy would be the same as that of the Denso and Beru mentioned above. Once you start venturing into the higher horse power applications it would be recommended to change up to the "one stage colder" plugs (mentioned above) as replacement to the Bosch OEM plugs.
http://www.neuralblog.com/_content/P...-707_pn-1.html
Old Jan 17, 2013 | 12:31 PM
  #45
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
I just had my plugs changed with 2667 NGK BKR7EIX and it made a huge difference in smoothness, etc in my car. 30k miles on it. The old plugs didn't look bad but the gap had widened considerably.
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
