Clutch Problem on Cold Starts
Old Dec 18, 2008 | 04:28 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Looks like something is up with my clutch. Got into the drive way, push the clutch to start and the pedal barely moves. I have to apply a huge amount of force to get it all the way down and start the car. I pumped it a few times and drove and it felt fine.
Before that I thought I felt the clutch not engaging when I was pulling the car out of the driveway when it was sitting for a while, but I always thought that was just my impression.
Then last week after driving about 5 lights Im sitting at a red, turns green, I start releasing the clutch and giving gas car doesnt move at all. I nearly release the clutch all the way and it doesnt even budge an inch. I press it down, put it in nuetral, pump it a few times and drive.
I had a "clutch line leak" when I frst got the car after about 2-3 months, and I really dont think my dealership did a good job, could this be related?
How serious is this? Should I bring my car in for service immediately?
PS. keep forgetting to check for any leaked fluids but will try tomorrow morning.
Old Dec 18, 2008 | 04:59 PM
sharkster's Avatar
Hmm could be your slave cylinder failing? Happens on the 996tt's a lot these days... How does the resevoir in the front look? Any fluid coming out?
Old Dec 18, 2008 | 05:41 PM
raiyu's Avatar
I'll take a look at it when I pull the car out of the garage, anything in particular I should be looking for or will the problem be apparent if thats what it is?
Old Dec 18, 2008 | 06:03 PM
sharkster's Avatar
Take a look in the front passenger side (pull the plastic panel off) and see if there's evidence of fluid/weeping etc....
Old Dec 18, 2008 | 06:43 PM
cannga's Avatar
Never met Alex yet continue to be a fan because of his always helpful suggestions; it's a good thing I don't live close to him or I'll probably be a bit poorer with the toys he offers. Anyway, the clutch slave cylinder has failed on a few 997 Turbo's -- seemingly more than any other component. I posted my problem here:
http://www.rennteam.com/forum/thread...eak/page1.html
Old Dec 18, 2008 | 08:09 PM
raiyu's Avatar
Looked fine from my rudimentary inspection, I guess its time to make a service appointment and have them fiddle with it.
Old Dec 18, 2008 | 08:59 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
If it shows leaking??? what is it slave or accumulator?
Old Dec 18, 2008 | 10:23 PM
TT Surgeon's Avatar
When I took mine in for svc they fixed mine too, it was leaking.
Old Dec 18, 2008 | 11:35 PM
ISOC8H18's Avatar
ISOC8H18 is infamous around these parts
/page1.html
+1 Totally Agree
Old Dec 19, 2008 | 08:04 AM
PorschePhd's Avatar
Wow, I didn’t think I would see this starting around again so soon. The slave or the accumulator is bad. I have heard of a few already but didn’t think it would be as bad as the 996TT as they changed them. Have the dealer fix it. They probably will put a whole new slave in it and been done. The bladder in the accumulator has failed or the two way check valve in the slave has given way and allowing the pressure to equalize rather than holding. The system is all power assist like your brakes. Much more elaborate but same concept
Old Dec 19, 2008 | 11:24 AM
sharkster's Avatar
Yeah no kidding eh? I can't believe it's happening on 997TT's already
Old Dec 19, 2008 | 02:48 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
I had similar symptons and it turned out to be a bad slave which was replaced by the dealer. The pedal was very hard to press down in the morning a few times, then the pedal won't come all the way back up. Eventually the pedal went straight to the floor when I apply any pressure to it, car had to go to the dealer on a flatbed.
Old Dec 19, 2008 | 03:11 PM
raiyu's Avatar
I guess I should wait till after the new year to make my service appointment otherwise I know it wont be worked on. I think it should hold out fine till then.
Can't wait to get the car out of the garage and drive through this snow to see how good the Pirelli snows handle this weather.
Old Jan 16, 2009 | 11:29 PM
raiyu's Avatar
Update: turns out it was a bad slave cylinder, replaced under warranty, good as new.
Old Jan 17, 2009 | 12:03 AM
docjackson1's Avatar
docjackson1 is infamous around these parts
glad hear the problem was easily fixed. i live in nj-who is your service dealer? by the way-i also bought the pirelli snows-mine have been doing fine in the recent snow-i am sure that you are having the same experience.
