Better Handling w/ Porsche Cup Front and Rear Control Linkage Changes, Etc.
Old Jan 1, 2009 | 11:28 AM
bluesea's Avatar
bluesea is infamous around these partsbluesea is infamous around these parts
At S-Car-Go in San Rafael, CA. I’m having installed, Porsche Cup lower control arms with TRG monoball bushings swapped in place of the stock ones. Also installed are TRG rear tow arms with monoball ends.
Additionally, I’m having aluminum tubes made that will take the place of the EVOMS hoses coming out of the intercoolers that lead to the turbos. One hose split and the replacement hose fit so poorly it came off. Since the new and old hoses matched I decided to go with a better solution. The boost should rise quicker without an initial loss of boost pressure soaked up by the expanding hoses.
The Cup control arm is a two-piece affair that allows camber adjustments by way of shims installed in-between the two pieces. In the first picture you can see the two attached pieces (the small piece with swapped TRG monoballs) without shims. The other bushing inside the arm (thrust arm bushing) is a TRG monoball swapped for the stock one. The other arm is my old stock one.
So far, one rear corner has been done. I’ll report on the handling once I get the car back.
I’m going to install a large button kill switch for the Passport 9500 ci so I can shut it off quickly if needed, without fumbling for the tiny on/off button on the stock control. As one of our sponsors asked before, I’ll post pictures of the installed components. Sorry it’s taken so long.
Old Jan 1, 2009 | 02:59 PM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
Are you going to be tracking your car?? Do you have the EVOMS 700 kit on your car?? If so how is it holding up and how many miles have you put on it? I really like the way your setting up your TT. Keep us updated on the out come of the suspension set up.
Old Jan 1, 2009 | 11:33 PM
TT Surgeon's Avatar
Looks great!
Old Jan 2, 2009 | 07:55 AM
Onibas's Avatar
Onibas is infamous around these parts
Good performance.
Wich is the prices?
Old Jan 2, 2009 | 09:04 AM
TPCRacing's Avatar
TPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond repute
We are about to release our package that includes these parts. We run and recommend to all of our 997TT clients to make this move... See the video in this post.
https://www.6speedonline.com/forums/...-included.html
Old Jan 2, 2009 | 12:21 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
I just placed the order for these and some other stuff from tarett.
Old Jan 2, 2009 | 12:29 PM
1200euro netto
Old Jan 2, 2009 | 02:07 PM
bluesea's Avatar
I will likely track the car. I recently joined the Porsche Club of America.
I do have the EVT 700 package. It's holding up as far as the engine staying together. I had a leaking intercooler core but Todd at EVOMS took care of it quickly. Alex at Shark Werks was right on top of things to facilitate it. A hose blew and I'm working on that. I have about 13k miles on the kit.
TT Surgeon,
Thanks!
Old Jan 2, 2009 | 08:17 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
I ordered mines from Tarett but mines have OEM rubber monobals I use the car in the street so I dont want a completly solid arm.
Now I think you need Camber/Toe locking plates.
Old Jan 2, 2009 | 08:39 PM
bluesea's Avatar
Mine aren't solid either, but I suspect that the ride will be harder than OEM. I'll look into the locking plates. Thanks.
Old Jan 2, 2009 | 09:02 PM
luiscarlos's Avatar
You mention you had TRG monoballs ...
Old Jan 2, 2009 | 09:40 PM
bluesea's Avatar
Yes. I see now. I thought there was some more rubber in there. The thrust bushing has a rubber outer piece though. I hope I won't mind the harder ride quality but I really appreciate a quicker response, so I'll likely come to terms with it all. I'll give a report after I get the car back.
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
