Help me eliminate RDK!!!
Old Jan 11, 2009 | 06:57 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Please can someone give me the sequence to KILL,DESTROY the RDK dash warning I use aftermarket wheels and I don't want to have the RDK active.
I went with 2 dealers and they don't know how to eliminate the RDK with the PIWIS.
I need step by step or a drill to blow the stupid red !
Old Jan 11, 2009 | 08:34 PM
PorschePhd's Avatar
I have tried everything. I have unprogrammed it, removed the modules, recoded...nothing has worked. So, as far as I know it can not be done. Sorry.
Old Jan 11, 2009 | 08:55 PM
TT Surgeon's Avatar
What's RDK?
Old Jan 11, 2009 | 09:02 PM
luiscarlos's Avatar
Thanks lets wait and see if someone tomorow can help us....
Old Jan 11, 2009 | 09:21 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
Chris,
It's the tire pressure sensor warning that puts a "!" on your dash or your TPMS in English or Rad Druck Kontrol in German.
Old Jan 11, 2009 | 09:25 PM
luiscarlos's Avatar
Originally Posted by ALPINE_997
Chris,
Ok and how can I eliminate ?
Old Jan 11, 2009 | 09:29 PM
ALPINE_997's Avatar
I wish I could tell ya. You have aftermarket wheels and you put back the TPMS sensors right?
Did you reset your pressure in the menu options and tell it that you changed tires? Mine did that a couple of times and I had to tell it it was partial load, summer tires in 19" - although I run 20's and its all good now.
Maybe bump up the PSI a little so see where it likes it.
Old Jan 12, 2009 | 02:01 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I had the same problem after installing my 20" gemballa wheels. I replaced all 4 sensors with new ones and reprogrammed them, i also used nitrogen instead of air, after that problem solved
Old Jan 12, 2009 | 08:25 AM
TT Surgeon's Avatar
Chris,
Gotcha, I have that light everytime I change rims, just reset it on the on board computer, usually clears within 10 minutes. You must use tpms sensors in all your rims though.
Old Jan 12, 2009 | 01:03 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I have the same problem. The dealer can't figure it out either. It used to just clear after resetting it. Now it seems to be permanent.
Old Jan 12, 2009 | 11:46 PM
TT Surgeon's Avatar
Make sure you are using the porsche tpms sensors, the ones sold by tr seem to be more buggy.
Also, metal valve stem caps will throw off the system, must use a plastic cap, or so I've been told.
Old Jan 13, 2009 | 02:31 PM
KrafTechnik's Avatar
KrafTechnik is infamous around these partsKrafTechnik is infamous around these parts
There's no reason you shouldn't be able to run RDK with aftermarket wheels.... Let me start by asking... did you put the sensors in the new wheels?
Old Jan 13, 2009 | 07:39 PM
luiscarlos's Avatar
I know I can run the sensors in aftermarket wheels.
I have 2 sets in my desk but I dont want to use them becuase they turn on really easy.
Old Jan 13, 2009 | 09:46 PM
SoCalCFP's Avatar
SoCalCFP is infamous around these parts
i have tpms with my hre p40's and no problem. after install, i had to reset/re learn the new wheels and it cleared fine. i had to read the owners manual to figure it out.
Old Jan 14, 2009 | 08:42 AM
ALPINE_997's Avatar
Well there is the problem. He is not running the sensors. He wants PIWIS solutio to turn off the warning light for the sensor without running the sensors.
Would have helped that you mentioned that.
