Porsche 997.2 Turbo LED Tail Light Conversion
Old Jun 16, 2009 | 02:42 PM
  #91
reymusic's Avatar
reymusic is infamous around these parts
i still have the warning light...we tried to change the modules,we change the pins as well and we still have the warning light..the 09 module didnt work great with the light i had the reinstall the original modile to have the light work,but i still have the warning light..
Old Jun 16, 2009 | 02:50 PM
  #92
bbywu's Avatar
Let me make sure I understand you.
You purchased the control units for the front and rear, as well as the LED tail lights.
You swapped the front pins, installed the front and rear control units and swapped out the originals.
You plugged in the harness with the LEDs, attached the LEDs, and programmed it with PIWIS, and you got a warning light.
I'm not sure I understand what happened next, but it sounds like you swapped back to the original light system, control units, but still have a warning?
Is this correct?
This may sound elementary or stupid, and you may have tried it already, but have you tried disconnecting the battery, touching the two terminals with each other (battery is disconnected) and then plugging the terminals back on to the battery to clear your ECU? This often resets the ECU and eliminates all warning codes.
Old Jun 16, 2009 | 03:08 PM
  #93
reymusic's Avatar
the technicians at Porsche told me they tried everything...the car went to porsche a couple of time and we still cannot get the warning light away...i just forwared him what you told me and see if he tried the same exact thing. i have the 09 front and rear mudules we are not even using them...we had installed the 09 front and rear modules and reprogrammed the LED and the warning light was still here...the lights are working fine ,but we do have the warning light on the dash
Old Jun 20, 2009 | 09:53 AM
  #94
No Partials's Avatar
No Partials is infamous around these parts
I am new here
Good morning, I have the honor or driving a pristine, '02 turbo coupe. Life is good. I am interested in installing aftermarket tail lights. Is there any advise I might receive. My desire is to not modify the surrounding area, just replace the old with new!
Old Jun 20, 2009 | 04:13 PM
  #95
sayegh87's Avatar
sayegh87 has a spectacular aura aboutsayegh87 has a spectacular aura aboutsayegh87 has a spectacular aura about
Hey, need help. I have a control module that needs to be plugged in at the body shop I am working with we cannot seem to find out were it should go. It is the front control module that needs to be hooked up in order for the LED lights to work. I just would like someone to tell me where it should go as it doesnt seem to fit under the front seat where the other control module is!
Any help would be greatly appreciated!
Old Jun 20, 2009 | 04:35 PM
  #96
Green Turbo's Avatar
Green Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to behold
What year is your car?
Old Jun 20, 2009 | 04:36 PM
  #97
To convert a 996 to 997.2 like my car you are looking at spending over $20,000. You can't just put the new tail lights on.
Old Jun 20, 2009 | 04:45 PM
  #98
sayegh87's Avatar
Its 2008 model.. I need to know where the front controll module plugs in to
Old Jun 20, 2009 | 06:38 PM
  #99
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Remove the front truck carpet right side and there goes the front led module.
I changed front and rear switch pins PIWIS reprog and it is not working!
Old Jun 20, 2009 | 07:36 PM
  #100
sayegh87's Avatar
Thanks for the reply, I have told the guy at the body shop and Ill go see what the outcome is in a couple of hours.
Old Jul 6, 2009 | 02:16 PM
  #101
reymusic's Avatar
any updates on the new Led taillight? im still having problem taking off the warning light....anyone found a solution? thanks
Old Jul 6, 2009 | 05:42 PM
  #102
luiscarlos's Avatar
I need the Techart led module part number.
Old Feb 2, 2010 | 05:11 AM
  #103
n1kos's Avatar
n1kos is infamous around these parts
help help help
hi guys im in uk and my local porsche are saying that. all i need to convert the rears is the rear led module which sits under the seat i beleave, i have allready done the bumper mods and put led gen 2 lights in
they also said that sometimes if you just plug in they have had cars in workshop that dont need piwis depends on software in car
also this module is it under the seat or under the carpet under the seat
cheers
also what is this swapping pins thing they have not told me to do this at all if so which ones do you swap??
im puzzled
2008 997 turbo
Old Feb 2, 2010 | 05:14 AM
  #104
n1kos's Avatar
the other option i was given was to use resistors in the rear loom on indicaters
sidelights
50w sidelights
25w each side indicators
this way i dont have to change modules its the same as converting the 955 cayenne to 957 cayenne rear lights
Old Feb 11, 2010 | 02:59 PM
  #105
dnorouzi's Avatar
dnorouzi is infamous around these parts
led tail light conversion
i have the same issue as one of the earlier posts: i have swapped the pins, replaced the front control module and programmed it at the dealer. I have two issues: turn signals are hyperflashing (blinking too fast) and warning light is on. Any suggestions?
