lowering springs
Old Apr 12, 2009 | 04:12 PM
scont07tt's Avatar
scont07tt is infamous around these parts
lowering springs
thinking of lowering car 20mm with techart springs mainly doing it for looks. what will the effect be on car handling wise and also will i need spacers keeping stock wheels for now might get p40"s later. i have asked about techart exhaust with switch valve but didnt get much feedback im thinking its not that popular anyone have it?
Old Apr 12, 2009 | 04:33 PM
997ttguru's Avatar
997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all997ttguru is a name known to all
it will improve your handling, but not by much. I would suggest Bilstein Damptronics than just the springs for these cars.
Old Apr 12, 2009 | 08:48 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
The difference between a good set of springs and damptronics is not as much as you would think. Spacers are not needed. The main benefit of the damptronics is height adjustability. If you want the maximum performance coil over there are other choices around but none are PASM compatible.
Old Apr 12, 2009 | 11:47 PM
997ttguru's Avatar
Bilsteins coilovers which I was referring, are PASM compatible.
Old Apr 13, 2009 | 07:19 AM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
I'm pretty sure Gasman realize that. He was referring to Bilstens damptronics are not going make the car handle much better then a pair of spring and that their are other coil over brands that are better for handling but they are not PASM compatible.. Least that how I read it..
Old Apr 13, 2009 | 07:56 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
We have installed H&R springs onto an otherwise stock 997TT suspension for a customer not too long ago. In theory it seems like a bad idea, and I suggested other alternatives, but the customer insisted. Once installed I was surprised at how well the car performed. Ride was very compliant and similar to stock.
I think it's not a bad option if you're simply looking for a quick solution. You can get a good set of Champion (H&R) springs for a few hundred $$ versus the cost of coilovers.
Last edited by Tom@Champion; Apr 13, 2009 at 08:11 AM. Reason: meant to say springs, not coilovers.
Old Apr 13, 2009 | 08:02 AM
TT Gasman's Avatar
Thanks Meaker, that's exactly what I meant. The OEM PASM dampers work very well with lowering springs for some reason. I also have the B16 PASM Bilsteins, and I'm betting the difference on the track will be small. But the main reason I did the change was for height adjustability. The car sits perfectly now, just slightly lower than stock.
The other options are the serious track coil overs like Motons and Ohlins etc.
Old Apr 13, 2009 | 10:21 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
I have H&R springs and love it. I chose that route because, IMHO it doesn't worth to pay more than 3x of springs price for PASM compatible coilovers. I have the experience of coilovers in previous cars and unless you track it hard, it is worthless. You even can buy sways to decrease body roll and yet save money than with just coilovers. As being said above, the springs works incredible well with stock system, is PASM compatible, it lower to the perfect height and improve the handling.
Springs + sways pack is hard pack to beat compared with just coilovers for a DD/few trackdays car.
Old Apr 13, 2009 | 03:55 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
stupid question: is a wheel alignment needed after just a spring install???
Old Apr 13, 2009 | 03:57 PM
gmoney's Avatar
Not a stupid question at all, and yes, its a must.
GMG springs + good alignment + GMG sways is a fantastic setup, very happy with mine.
Old Apr 13, 2009 | 04:03 PM
nyamg's Avatar
i think i'm going to go with your exact setup as opposed to Bilsteins, and I'll save a ton of money, I don't track the car so this should be more than enough to "tighten" the suspension up.
Old Apr 13, 2009 | 06:19 PM
Tiago's Avatar
What is the difference between GMG and H&R sways?
Old Apr 14, 2009 | 07:16 AM
997ttguru's Avatar
Oh ok, sorry then
Old Apr 14, 2009 | 08:07 AM
TT Surgeon's Avatar
Highly recommend GMG spings and sways, alot of the other springs tend to sag alot after a few months. Mine have barely settled more than an 1/8" since install a yr ago.
Valentino, if you want to take a ride in mine before you decide, let me know.
c
Old Apr 14, 2009 | 08:10 AM
TT Surgeon's Avatar
GMGs are a larger diameter and apparently slightly stiffer and fit better, contact Fab at GMG for the specifics or ck out their website.
c
