The VR750 Package is Here. Did I Hear Affordable Horsepower?
Vivid Racing is proud to release its new VR750 horsepower kit for the Porsche 997 Turbo. This kit was developed as the intermediate level to our VR630 and VR800 performance kits. The VR750 features a variety of quality, tested racing products to give you a reliable, daily drivable, and high output performance vehicle. As tested here in our Gilbert, Arizona facility. The VR750 turbo kit put out a very strong 616awhp and 632ft/lbs of torque with the Mustang Dyno correction factor. Our test vehicle was a 2007 Porsche 997 Turbo Tiptronic. The car reached its final number using VP109 octane unleaded fuel at 1.3bar of boost. As tested on pump gas, the car still made an impressive 557 awhp and 600ft/lbs of torque. With an ambient temperature of 92F in our dyno room, cooler temperatures and a 6speed transmission can only mean more horsepower!
To further the testing of our VR750 turbo kit, we immediately sent it off to run in the 2009 Gumball 3000 rally from LA to Miami. With 7 days of hard driving, 2 track events including a road course and drag strip, as well as high speed runs, this was an excellent test to put the car through beyond its dyno numbers. As vehicle owner Caleb Garrett stated, “The huge low end torque increase over my previous mods was very noticeable. When the turbos hit the car was a rocket pulling hard all the way to redline.” By retaining the VTG turbo setup, we are able to maintain fast spool up for those wanting a strong streetable setup. By not eliminating the VTG design, there is no need for changing oil lines, coolant lines, or other components found on a standard Garrett based turbocharger. Each turbo is disassembled and rebuilt with a larger turbo wheel that flows almost 40cfm more then the stock units. The end result is a brand new modified turbocharger.
In order to achieve this performance increase, it is necessary have proper tuning of the Bosch ECU. Vivid Racing has been a partner of Softronic who has been tuning ECUs and building Porsche engines for nearly 30 years. The Softronic tuning procedure is far more complex then others global changes. By adjusting the timing, air/fuel ratio, and boost, Softronic pulls out the potential of your car in a safe, reliable, and check engine light free world.
With any larger turbo package, it is necessary to upgrade additional components to maximize the performance of the vehicle. Vivid Racing has partnered with Agency Power who produces some of the best quality, race tested components on the market for the Porsche turbo vehicle. We include the performance exhaust system, VTG racing headers, high flow intercoolers, silicone boost hoses, and our powerful carbon fiber cold air intake kit. These products in combination with the turbos and ECU flash help launch your vehicle to the next level.
For those owners with a 6speed manual transmission on the Porsche Turbo, we recommend upgrading your Clutch to the Clutch Masters Stage 3 Unit as well. This full disk is designed to hold up to 800 horsepower with an OEM feel. The easy engagement comes from Clutch Masters fiber tough material and steel backing disk which is built from OEM Sachs clutch components. This clutch will hold all the power you need on the street, strip, or track.
This kit can be customized if you already have some of the included products. Vivid Racing offers vehicle transportation and installation at our Arizona facility. If you have any questions regarding this package, please contact us at porsche@vividracing.com.
The VR750 Kit includes:
Complete product info is located here - http://www.vividracing.com/catalog/v...7-p-65514.html. For those that already have all the bolt ons and just need the turbos and ECU flash, stay tuned for seperate pricing.
- Agency Power High Flow Intercoolers
- Agency Power Carbon Fiber Cold Air Intake
- Agency Power Silicone Boost Hoses
- Agency Power Performance Exhaust
- Agency Power VTG Headers
- Clutch Masters Stage 3 Clutch Kit (Original Core Required
- Softronic Custom Tuned ECU Flash
- Modified VTG Turbos (Original Cores are Required)
Thats good price dan..If you have them earlier I would def get my set from you with my wholesale account
but I had the EVT700 already..
Are you planning to do the 800 or maybe 850 kit anytime sooner?
but I had the EVT700 already..Are you planning to do the 800 or maybe 850 kit anytime sooner?
Yeah it is about $5000 cheaper then the competition. But for those that already have all the bolt on modifications, you can buy just the Softronic ECU flash or the modified turbos from us too.
I got turbos here and for a track junky like you, this is the way to go! Also if you confirm I can probably get us on the Bondurant road course for you to test out the new Motons and turbos
It is all possible, i will make this decision after i get there bud. i found a transport to put the car on; flat 16x7 it should work out fine. I will let you know when i hit the road, you guys open Saturday? if not, i may need a way to PM or TXT you.
