exhaust or ECU first?
Hmm tough question.... If you absolutely "hate" the sound of a stock exhaust then that's the way to go. In order to get the best out of an ECU mod it's certainly preferable to get an exhaust to get rid of some back pressure. But if you're ok with the stock exhaust and just want some more power the ECU is your first port of call.
Well said Alex. Joecmess, it also depends on your situation. im my case for example, i cannot do the exhausts (for now) otherwise the dealer will cancel my warranty. So the ECU is the best thing for me, since i can change the Program setting back to stock prior to taking it to the dealer. also in terms of power. i think the ECU will give u more power than exhausts. so i say ECU. Best of luck in your decision
i would do the exhaust first, you will be happy for the small bump in power (20hp) and the pant dyno will be happy too with the sound, after somme weeks you will be ready for the big jump in power caused by ecu flash and the exhaust will add this for the reducedd backpressure.
Exhaust with high flow cats will decrease backpressure and significantly reduce lag. OEM cats have 600 cells per square inch (CPSI.) Most low flow cats are 200 or 300 cell units. 100 cell units are best, but require ECU reprogramming to prevent CEL warnings.
If you want to reduce lag, a good exhaust works helps a lot. Not to mention, decreased EGT (exhaust gas temperatures) which is always good especially if you reprogram your ECU in the future.
if you want improved sound quality, then the exhaust is a must. if power is more important, then you should go with the ecu first. however, getting both is ideal if you can swing it.
Hey Joe! Long time no speak.
This is hysterical...I just went through the same mental process! I today ordered PSS10s and GAIC flash! I'll be doing exhaust next. Why don't you get the exhaust and then we can check out one another's cars for comparison? Sounds fun to me!
Warranty
Speaking from personal experience a new exhaust system and or an ECU reflash will void your warranty with most but not all dealers. If the dealer wants to check carefully, they can tell your ECU has been reflashed. This may just be me, but if you start modifications you know (or should) your warranty is mostly if not all toast. If not sure, talk with your dealer in advance. No disrespect intended, but why lie? If you really want to blow your mind, read the warranty that comes with the car! No mods, no tracking, etc.
Anyway, I did new exhaust (immediately), then suspension, and then ECU - different strokes for different folks and it's all good.
K.
P.S. Warranty and mods is an old topic (do search).
K.
Bilstein PSS10 damptronics with ride height lowered 1 inch
Exhaust - AWE, Fabspeed, Cargraphic - which one??????
Giac Ecu flash
and then track, track track
I either wait until I can swing all, or start with one mod at a time. Who is doing the install? When are the meets?
We are on the same page Joe!
I spoke to a few vendors...some of which are highly recommended here...but in the end went with Alan at Jack Daniels again.
I'm sure there will be another meet soon.
I'm also struggling with which exhaust to get as well...JDs is having a motorsports day in a week or so...why don't we meet there? Alan said that all the mods you would ever want to see will be there to check out.
So I guess you bought the car out at lease termination??
K.
K.
So yes to get the most "power" from the get go.. the ECU is the right first mod. Only thing is that I don't believe in having the same one file for all cars/situations. So if you have a stock exhaust make sure your software is set up for those hardware parameters. If you upgrade to an exhaust at a later date then make sure you get your ECU/software updated... That's the only drawback of doing the exhaust at a later date... That and the extra $. Keep your eyes open etc... I've seen a good few used exhausts out there for cheap too.
