Suspension or exhaust
Old Aug 29, 2009 | 08:08 PM
il nino's Avatar
il nino is infamous around these partsil nino is infamous around these parts
I have the GIAC upgrade and am considering an AWE exhaust or a Tubi exhaust or a suspension. Any comments?
Old Aug 29, 2009 | 08:39 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
you can have all the HP you want but if your car can't stay put, it is worthless.
First thing I ever do on any vehicle is suspension work. Most "spirited" drivers on here do the PSS10's I guess it depends on what you are looking for but the exhaust is a must with ECU tune... I strongly suggest you do suspension first as it will not cost you much more than the exhaust unless you went with a real one
Old Aug 29, 2009 | 10:23 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
Reading the title, I was going to suggest suspension. Realizing you have the GIAC flash, I think you should get an exhaust. If you plan to spend any time at the track (or on spirited drives), then just start collecting change from under the sofa cushions now because you are going to want to do the suspension too.
Old Aug 29, 2009 | 10:51 PM
cannga's Avatar
Agree with both KA and sparkhill. At this point you are stuck and sort of "need" to do both. Isn't this hobby great?
You are obligated to do the exhaust because you need to get rid of the back pressure caused by the 600 cell density stock exhaust, so that the ECU tune could work appropriately.
You need to firm up the stock suspension because with this much power, your car is probably now acting like a drunkard with all the weight transfer.
There is a big difference in price between AWE and Tubi. So doing AWE and suspension may be a good choice; if your question stems from budget concern and if you like the sound equally (they sound totally different from each other btw).
Good luck and have fun, and sorry the answer is not so simple.
Old Aug 29, 2009 | 11:01 PM
gt2urbo's Avatar
gt2urbo is infamous around these partsgt2urbo is infamous around these parts
i noticed a huge improvement with coilovers
Old Aug 29, 2009 | 11:59 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
I vote for suspension. It's the first thing I concentrated on before any other mods. I love the transformation. Took it to the track today and can you say WOW?!
Remember, the car is plenty fast already stock...just somewhat clumsy when you get on it.
Old Aug 30, 2009 | 12:16 AM
oc997's Avatar
oc997 is just really niceoc997 is just really niceoc997 is just really niceoc997 is just really nice
I vote for AWE exhaust. Love the one i got and i felt a difference in the delivery of the power and boost after i installed the exhaust.
I def also recommend doing the suspension and would do KW HLS or the new Bilstein lift system so that you have front ground clearance and are not always replacing your front lip.
You cant go wrong either way. GL
Old Aug 30, 2009 | 01:17 AM
freeman's Avatar
freeman is infamous around these parts
Get exhaust first if you mainly use your car on street.
If you want to track your car, just get some R-comp tires.
Race alignment + Sway bars + R-comp tires are good enough for most track days.
When you are getting more serious, get a real set of fully adjustable suspensions + hoosier R6s(or alike) to take full advantages of the better suspensions.
Old Aug 30, 2009 | 06:40 AM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Totally agree - you probably already put the cart ahead of the horse by doing the ECU before the exhaust. Do the exhaust to "unlock" the ECU. I have the AWE exhaust & GIAC but have yet to do anything to the suspension for fear of making the ride even rougher over our lousy Pa. roads and I don't track the car.
Old Aug 30, 2009 | 07:36 AM
raclaims's Avatar
raclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to behold
I did the flash before the exhaust as well and it was still damn fast...but the exhaust improved things dramatically...as did the suspension upgrade.
You don't live far from me if you want to take my car for a ride you are welcome to...
Old Aug 30, 2009 | 08:00 AM
MBailey's Avatar
Depends on how you use the car...
If you track it, get the suspension.
If you just use for street get the exhaust.
Old Aug 30, 2009 | 09:06 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Tubi and a good alignment as a start. Check the classifieds on here, from time to time you see top tier exhausts like the Tubi for sale.
Old Aug 30, 2009 | 09:31 AM
bbywu's Avatar
+1
You're never going to get a consistent answer. I'd bet the answers here are going to be right down the middle.
This is the reality. The weakest link in the 997TT is the suspension. The soft setting is too soft for spirited driving. The firm setting will snap your tail bone. Body roll is significant, understeer under throttle is overwhelming. Rear end is sloppy.
Despite this, the 997TT is still an exceptionally handling car. Very few owners are capable of driving it to exploit its limitations, most here on the forum are incapable of driving beyond the limits of the current suspension setup. For those who upgrade to Damptronics, only a handful of drivers really need this setup. To need a setup beyond this, you're driving skills are probably at instructor level or better.
As far as the exhaust is concerned...it always compliments a ECU by lowering restriction, backpressure, and EGTs. It is usually the first set of modifications that people move toward when they want more power.
You need to ask yourself what you want to do with the car...is it a daily driver? Garage queen? Track rat? You could get hundreds of different answers about what the next mod should be, and spend $$ until the cows come home, but you won't be happy until you ask yourself these few questions.
Old Aug 30, 2009 | 09:56 AM
TT Surgeon's Avatar
Since you've already done the ECU, you gotta do an exhaust first. The stock suspension is more than adequate for street/light track duty, just needs a good alignment.
Old Aug 30, 2009 | 12:45 PM
996TTer's Avatar
996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute996TTer has a reputation beyond repute
Originally Posted by tt surgeon
since you've already done the ecu, you gotta do an exhaust first. The stock suspension is more than adequate for street/light track duty, just needs a good alignment.
yep!!
