Cabin fills up with smell of gas sometimes???
Old Dec 8, 2018 | 08:33 AM
lliejk's Avatar
5 Year Member
lliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud oflliejk has much to be proud of
Is it possible the fuel fumes catch system (whatever that is for the Porsche) could be failing and you are smelling that? I know many vehicles strongly warn about overfilling the car and I know there is a system to protect the environment by catching fumes from the tank. Could this system be compromised somehow?
Ed
Old Dec 10, 2018 | 07:17 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Ed
Yes, I am taking it in to get a check out and switch out my fuel pump, venturi tubes and tank gaskets this coming Saturday.
Old Dec 27, 2018 | 12:10 PM
Isthisforeal's Avatar
5 Year Member
Isthisforeal is infamous around these parts
Had this issue on my 996tt which did eventually pop a code. My issue was the fuel pump cap had cracked/melted from the wire having resistance the fuel pump is located under your front trunk might be worth a try to whiff around there when you smell the fuel.
i ended up cleaning the wires and using jb weld to fix the crack on the pump lid. Its been over a year without issue
Old Dec 27, 2018 | 12:31 PM
turboslut's Avatar
Yeah I just recently replaced my fuel pump and venturi tubes along with the cap and sealing ring....only to find out after the fact that my manifold bolts had backed out a bit causing an exhaust leak (and gas smells).
Old Jan 5, 2023 | 09:32 AM
DGT3's Avatar
DGT3 is infamous around these parts
Me too
[QUOTE=Porsche951S;2672567]I just got my 997 Turbo and notice sometimes when sitting at a light or slow cruise that the cabin fiills up with a strong smell of gas.. No lights have come on and its quite random but im still concerned.. Any ideas?
I have your issue in my 2009 turbo
BLKMGK
May 31, 2016 04:32 AM
uurfantasy
Sep 23, 2015 09:10 AM
Lucid Moment
Sep 12, 2015 01:12 PM
