Pbox result-comments/critiques?
Old Feb 22, 2010 | 01:09 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I'm throwin' this out there gentlemen. Here's my first attempt at using a P-box as well as attempting a 1/4 run. I want to put my mods to a test. Conditions: 58 F, calm, 93 octane.
1/4 mile results:
0-60 5.8 (very soft launch, not a launch at all really, didn't want to roach my clutch)
124.0 Terminal Speed (13.8 s)
Note: Elevation 1000 ft which corresponds to about 7% less O2 than at sea level.
Waddaya think?
Last edited by TTdude; Feb 22, 2010 at 10:23 AM. Reason: Corrected "Trap" to "Terminal" vis-a-vis VividRacing Tx
Old Feb 22, 2010 | 08:50 AM
gmoney's Avatar
is your clutch stock?
Old Feb 22, 2010 | 09:40 AM
TTdude's Avatar
No, my best guess is that it's a "stage 2" Sachs whatever that means. The guy who built the clutch wouldn't tell me what all the components are, claiming "we don't reveal our trade secrets". It feels great, however, better than stock. He said it would hold and it's doing that for now. We'll see what happens down the road. I'm guessing it's a 764 pressure plate and possibly GT3RS clutch disc, but that's just a guess.
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
you need much faster gear shifts
good is 0.25s great 0.2s, excelent less than 0.15s
Old Feb 22, 2010 | 09:43 AM
bbywu's Avatar
It is a little hard to interpret your run as it appears that you really granny launched it and took it easy on the shifts. You should ask Scott "divextreme" or the other subject matter experts on the 60-130 thread on the 996TT forum for their opinions. I would have expected you to trap 130 or better, as I believe your setup is putting down mid to high 500 whp?
Old Feb 22, 2010 | 10:08 AM
TTdude's Avatar
And I thought I was doing pretty good-no missed shifts. Man, do I have a ways to go. Good to know these benchmarks-Thanks.
Good suggestion. If nothing else, posting this on the 996tt forum will serve as entertainment value. I'm actually not certain what this set-up is actually putting down, hence the testing. My guess it should be high 5s. The Proto tune feels great, however--100% satisfied. In all fairness, it's a "generic" VTG file and data logging should help tweak it some.
Old Feb 22, 2010 | 10:19 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
The "trap speed" you posted is not the actual trap speed like at a drag strip. The speed the Pbox gives you is the terminal speed at the end of the run. The trap speed is typically 2-3 MPH slower than the PBox terminal speed. Thanks for posting your result.
Old Feb 22, 2010 | 10:33 AM
TTdude's Avatar
You're right. Shift times suck. See plot.
Old Feb 22, 2010 | 10:40 AM
sharkster's Avatar
hmm I was thinking you'd have a quicker mph tho? What octane?
Old Feb 22, 2010 | 10:44 AM
TTdude's Avatar
93. I was thinking the same. It looks like slope gradually diminishes from 2-3-4.
Old Feb 22, 2010 | 11:06 AM
landjet's Avatar
That's to be expected.
Old Feb 22, 2010 | 01:28 PM
yrralis1's Avatar
When we talked awhle back I felt something was off . I just am not sure what .
I also am not sure what a " soft launch" is.
There was some debate awhile back with a guy on the 997 section who was dropping his clutch and claiming wheel hop and most called him out on it --explaining that this rough method of driving was not only bad for the car but that it also wasn't efficient. Efficiency is so important. That's why the PDK turns ups a great time with a stock car.
To me the best launch comes with not guessing the point of engagement . It's like competitive diving or gymnastics where there's an element of timing to nail the entry or landing. The Turbo clutch with power assist .. does not make this easy .
Even still .. those times just seem like repeated tests and looking at the average might be the next step to get a clearer picture.
Old Feb 22, 2010 | 02:00 PM
TTdude's Avatar
Agreed. I need to get some more data points to see where these mods accurately stand. I'm really a novice at this and it shows. Very few people post data, anyhow, and those that do post only their personal best which is understandable. I'm sure tuners don't want people posting sub-optimal times of their products but that is not my intention. I am viewing this as an evolution and learning experience. I feel there is significantly more I can tap into with this set-up. We'll see how it goes.
Old Feb 23, 2010 | 10:25 AM
uaeturbo's Avatar
uaeturbo has a spectacular aura aboutuaeturbo has a spectacular aura about
on 93 oct. U should trap 128 to 130 mph
k_ddsl
Mar 20, 2014 10:02 AM
k_ddsl
Aug 9, 2010 08:32 PM
k_ddsl
Jul 3, 2010 03:22 PM
KPG
Oct 12, 2007 03:43 PM
