Need Help ! Proto GT3076 KIT
Old Mar 8, 2010 | 06:38 PM
Nasser's Avatar
Nasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant future
Unhappy Need Help ! Proto GT3076 KIT
hi every body
i finish tuned my car today , Todd make me the ecu
when i drove the car the intake is touching the tires !!
(( one of my frindes told me to fix 7 mm wheels Spacer ! )) and it should work fine
and i accelerate when i reach the 5th gear the boost gose down !!
i need your tips ! if you can tell me any info
Old Mar 8, 2010 | 08:00 PM
P2P's Avatar
P2P
P2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the rough
Its better to ask Todd him self. He will Give u all the help u need.
Old Mar 8, 2010 | 08:12 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
nasser thats a very bad news call tod and see what the prob .. and i believe its a good time now to call him so dont waste ur time
Old Mar 9, 2010 | 12:29 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
As far as i know Todd is in Bahrain at the moment, if i was you i would ask him to come over, he is not far from you
Old Mar 10, 2010 | 09:57 AM
Blackout713's Avatar
Blackout713 is infamous around these parts
Todd should know whats, up. He can log your data, and see if you need to get retuned.
using a spacer is a quick fix, but i wouldn't want your wheels rubbing on the fender. What size exhaust housing does your prototype gt3076 turbo have? around what rpm is boost dropping off?
Old Mar 10, 2010 | 11:17 AM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Where did you installed the kit?
They might instale it wrong, i used the same intake and if they instale it wrong it will hit the tire.
Go to MTM in Dubai they know how to fix it.
Old Mar 10, 2010 | 11:19 AM
997John's Avatar
for the boost drop, check for boost leaking also MTM can do it for you
Old Mar 10, 2010 | 04:46 PM
Nasser's Avatar
im going tomorrow for them =(
i solve every thing today , but i have problem with clutch
and the drop in the 5th gear and some times with all gears
and its return ok when i switched of the car and turn it on again im realy tired from this problems =(
Old Mar 10, 2010 | 04:55 PM
P2P's Avatar
P2P
MTM is ur way .. check with them
Old Mar 10, 2010 | 05:10 PM
Nasser's Avatar
ill take it there and i hope that they can do something
Old Mar 10, 2010 | 05:35 PM
gmoney's Avatar
if your using the stock clutch you may see slippage in the higher gears.
and I would also guess this is an install issue, somethings lose or misaligned perhaps.
Old Mar 10, 2010 | 05:38 PM
P2P's Avatar
P2P
+1 for sure
Old Mar 11, 2010 | 01:35 AM
Nasser's Avatar
its CARBONETIC Triple Carbon Clutch
Old Mar 11, 2010 | 02:02 AM
P2P's Avatar
P2P
BTW what's ur tire size ?
I saw many having the same prob in this forume
Jul 29, 2019 11:13 AM
Perkman87
Nov 19, 2015 05:31 PM
ECS Tuning - VW
Aug 27, 2015 08:50 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
Aug 21, 2015 06:34 AM
