Calling cannga...possible solution to "the click"?
Old May 13, 2010 | 04:36 PM
freeman's Avatar
freeman is infamous around these parts
Did i received the correct drop links from Tarett Engineering? They look different than can's version. I ordered the one for after-market coilovers and sways though.
I have Bilstein + GMG sway bars on my car.
Why one bolt is longer than the other?
Old May 13, 2010 | 08:30 PM
TT Surgeon's Avatar
You'll see when you install it, that's the way it picks up the bracket.
BTW, I agree 100% with Neil M, the issue is mating bilsteins to aftermarket sways. I hold that the position they are attached to the bar has a minimal effect. Everybody I know who has an OEM front bar, bilsteins and the dlink mounted inboard, as per the bilstein instructions has yet to pop a link. I have personal knowledge of 4 cars around me with no such issues, all 4 cars see the track regularly. Just sayin....
My solution:
They're baaaaaack!
Old May 13, 2010 | 09:33 PM
rated_m's Avatar
rated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of lightrated_m is a glorious beacon of light
The one you have looks like the one that replaces the cinch bolt on the hub carrier, which is why one bolt is longer than the other and the drop link is shorter. The drop link that mounts to the shock blade is longer and both bolts are equal length.
<O</O
Which one did you pick? Tarret shows one for 996/997 TT/C4 and the other I think shows 996 TT/C4.
Old May 14, 2010 | 01:49 AM
freeman's Avatar
<o></o>
(Model = 996/997 TT/C4 w/ Moton, JRZ or JIC Struts, 997 TT/C4 w/PSS9/10 (Part #FDLNK9) )
(Option = Add Boots)
That is exactly what i selected when i ordered mine.
They seem quite short even at the longest adjustment compared to drop links supplied with bilstein coilover kit.
Old May 14, 2010 | 08:16 AM
rated_m's Avatar
I ordered the same part and got the longer ones that mount on the shock blade but with out the boots.
Mines still hit's the hub carrier at full lock, Tarret is sending me spacers to push the top mount further back, I hope that will fix the problem.
Old May 14, 2010 | 10:07 AM
cannga's Avatar
Hi Fred, you got the one with the rubber boot cover - great. I believe this is the latest addition to the Tarrett drop link and is there to prevent dirt to get into the joint -- all a result of Larry/Hummv's recommendation.
I would call/email Tarrett to confirm if this is the right one. One thing to add: position and thickness of bolt/washer could be changed depends on sway bar, with the goals being a straight connection and good clearance of the connection (drop link body doesn't touch the coilover, etc.). If you think you need a shorter bolt or thinner/thicker washer, let Tarrett know and they will send it to you. Good luck and have fun.
An example is the rear drop link of my car:
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Oct 6, 2015 05:20 AM
terminal_ac
Sep 12, 2015 03:26 PM
Ferrari
Aug 24, 2015 04:35 PM
