997 Turbo lug nuts
997 Turbo lug nuts
I'm buying a set of black wheels for my 08 TT. Want to go with black lug nuts. Any suggestions for new ones that are equal to or exceed the factory lugs?
I have a set of titaniums that I don't use anymore because I'm using spacers. PM me if interested.
If you have a ceramic coating shop in your area and can put your car on jack stands for awhile, try a black ceramic coating. I had my stock lug nuts ceramic coated, and they still look good after three years. Cost was about $60 and the shop did the job in one day.
The main consideration becomes the chamfer on the nut matching the wheel. If it matches then you can use the stock nuts. If the chamfer doesn't match then there is a risk of the nut backing out. I've used the GT RS wider wheel (no spacers required) on my turbo with no problems.
Thank you!
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
