Should i use 5/40 oil?
Old May 9, 2010 | 04:31 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Hello there...i bought my car with 23500km...Previous owner used mobil1 0/40 until 20000km (he changer them at 7,14)and then replaced them with redline 5/40...i switched back to mobil 0/40 at 26000km,two weeks ago...The problem is tha when i start the car after a few days of garage sitting it makes a horrible noise (probably from lifters?)such as there is no oil for about 1/3 of a second and then oil pressure goes up and the noise stops...engine is running fine...With redline this noise did not happen...any ideas?
P.S. the car has almost no oil consumption...
Old May 9, 2010 | 06:37 PM
Serpentene's Avatar
Serpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant future
turn ignition to on..and wait a few seconds (3) before starting the motor.
Old May 10, 2010 | 03:10 AM
I ll try that...But what it does?
Old May 10, 2010 | 05:27 AM
landjet's Avatar
It gets hot in Greece, maybe 5w50 would work well there. That's what I use.
Old May 10, 2010 | 08:09 AM
etchu's Avatar
etchu is infamous around these parts
some said 0w40 for normal use and 5w40 for hot weather with aspiring driving use.
Old May 10, 2010 | 09:18 AM
drkbrent's Avatar
drkbrent is a jewel in the roughdrkbrent is a jewel in the roughdrkbrent is a jewel in the rough
I immediately noticed my engine running smoother with the 5w-40 oil (I use Lubromoly by the way). I was rather shocked about all the little "noises" the engine used to make before the switch...they simply disappeared after using the 5w-40. For what it's worth, I know many folks who also use a 5w-30 grade oil (although not recommended by Porsche). The 5w-40 grade shears to a 5w-30 after about 1,000 miles anyways...Mercedes Benz V12 bi-turbo engine calls for a 5w-30 which I thought was interesting...
Old May 10, 2010 | 09:22 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
might allow some pre-start oiling to occur
Old May 10, 2010 | 09:34 AM
TPCRacing's Avatar
TPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond reputeTPCRacing has a reputation beyond repute
We run 5-40 redline in all of our high hp cars.
Old May 10, 2010 | 09:44 AM
XLR82XS's Avatar
I ditched the 0w-40 Mobil 1 for Pentosin 5w-40. The car does seem to run better all around. (cold, hot, not as noisy) This recommendation came from David Laing at GrandSport. Pentosin is approved by Porsche. If anyone has any questions why I'm sure he would be more than happy to discuss with you. http://www.grandsport-michigan.com/home.html
Old May 10, 2010 | 02:59 PM
thank you all guys...
Old May 10, 2010 | 05:14 PM
speed21's Avatar
Absolutely nothing. The oil pump/s of the the engine are not electric and begin working when the engine is physically turning over either by the starter or under its own steam.
If your engine is making lifter noises on factory spec mobil one then that could be due to a number of reasons. Adding thicker oil usually helps to compensate for worn components by quietening down excess running clearances. The low mileage of the engine is inconsequential if it has been subjected to abuse,high combustion temperatures, and/or poor servicing regimes.
Old May 11, 2010 | 08:12 AM
i am trying to figure out whether an engine that uses 5/40 oil for 4000miles and then changed back to 0/40 has "learned" 5/40 oil...Yesterday i started the car in order to video tape the noise...but it was silent... we will see...i really dont know if the 5/40 had any additives that are missing now...
Old May 11, 2010 | 04:21 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Exclamation
has anyone tried a 0w-50? it seems like that would give you the best of both worlds: http://www.chrysanstore.com/enmooil0wgra.html
http://www.mobil.com/USA-English/Mot...ing_0W-50.aspx
Old May 12, 2010 | 05:36 AM
speed21's Avatar
No, engines dont "learn" oil. Heavier or more viscous oils are often used to mask an excess running clearance problem but eventually these kinds of noises will continue to re surface unless you keep thickening the oil with additives. It really depends on what the actual problem is (that is if there is any here) and, if there has been any scuffing anywhere at one point that damage will eventually cause the affected components to fail anyway. If your engine is now silent thats a good sign but id still check what your oil pressure is doing when the engine gets to normal operating temperatures after a good run. If it is sitting a bit below the minimum then thats not a great sign. You obviously have concerns so look for the obvious signs when the engine heats up such as lower than normal O/P, abnormal smoke, smells, sound of engine etc. I Hope its fine..
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
