Does FVD flash raise rev limiter?
Your tune was set at 7200 and would record over revs when hit up to and at 7200. Should it be moved to 10,200 then that would be the rev limit. Lets keep in mind that there was a time when cars had no rev limiters and required a eye on the tach so this route could be used also. The 10,200 would basically be that.
The answer is in the tune and not what flashed the car. This is the same reason some tunes make more HP than others etc. There is also multiple rev sections in the 997 and GT2 files.
Best,
Scott
Best,
Scott
Feelgood MD
Mar 24, 2016 09:35 AM
shifter_
Sep 2, 2015 03:33 PM
