Durametric Data Logging
Old Jul 4, 2010 | 12:31 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
if i want to do data logging in 6.0 Durametric
i want to know whats the A/R ,, the boost Pressure and the timing during the full throttele
so can you please tell me Instructions
thanks
yousef
Old Jul 4, 2010 | 12:46 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
will be interested in same info as I just received my cable
Old Jul 4, 2010 | 12:49 PM
bbywu's Avatar
I do not use 6.0B to datalog. I use 5.0.
Boost on demand during WOT is not directly measured.
You need to calculate the value based on ambient atmospheric pressure using Durametric v5 (6.0B variable seems to be labeled differently.)
"Boost pressure of sensor" is an actual value, and it is displayed in mbars. Ambient pressure needs to be recorded as a constant. Under acceleration, the sensor reading needs to b e corrected with the ambient pressure constant.
ie
990 mbar at idle
At 6734 RPM WOT, I will record 2178.75 mbar.
2178.75
- 990 (reading at idle) =1188.75 mbar / 1000 = 1.18 BAR
For Lambda, multiply this with 14.7 and you'll have the correct air fuel ratio.
bob
Old Jul 4, 2010 | 01:35 PM
ysfg35's Avatar
great info bob ,,
what about timing ??
Old Jul 4, 2010 | 07:51 PM
bbywu's Avatar
Originally Posted by ysfg35
great info bob ,,
Log RPM and Advance (which will give you ignition angle or timing.) I should also mention that you need to record Lambda for bank 1 and 2, and at high RPMs, the sampling rate may be insufficient to accurately record Lambda.
I've started to compile a list of useful threads for using Durametric Software.
https://www.6speedonline.com/forums/...-software.html
If you have something useful that you have learned about the software, and would like to share with the community, please let me know so I can add it on.
- bob
bob
Old Jul 4, 2010 | 10:05 PM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Engine speed
Engine load
Ignition angle
Actual lambda value bank 1
Actual throttle plate angle
Pressure ahead of thr. Plate press. Sensor.
Old Jul 5, 2010 | 06:03 AM
ysfg35's Avatar
thanks all i will try this soon
thanks alot
yousef
matt2ace
Nov 23, 2019 11:38 AM
White991TT
Mar 8, 2016 06:01 AM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
