Custom dyno tune? Would it be beneficial?
Old Jul 19, 2010 | 03:50 PM
camdon's Avatar
camdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant future
Would it be more beneficial to do a tune with a compnay that can do a dyno tune or is a basic plug and play flash going to be just as good ?
Old Jul 19, 2010 | 07:52 PM
FLT6SPD's Avatar
FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !FLT6SPD Is a GOD !
It would always be preferred to have a custom tune for your specific mods, climate/altitude, ect.
Old Jul 19, 2010 | 07:58 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
^^what TJ said. But also depending on who you're dealing with, will likely be a lot more $$$ as well. Probably not worth it unless you have lots of aftermarket bits and are putting out a lot more power over stock.
Old Jul 20, 2010 | 12:07 AM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
If all you have is a standard after market 200cpsi exhaust and filter (BMC or K&N) then you probably don't need a dyno tune. BUT, if you have ANYTHING ELSE it's worth a couple $100 to get the right tune.
If you have someone local that you trust I would say go with whatever tuner they support, no matter who it is. Local support is way more important than who the tuner is. And 'local' is relative as I drive 3 hours to see my guys but it beats sending the DME back to Germany, ala Ruf.
Old Jul 20, 2010 | 12:27 AM
bbywu's Avatar
But I'd bet that the 3 hours back after your tune was one of the best drives you had in a while...
Old Jul 20, 2010 | 12:33 AM
ruf_turbo's Avatar
Amen brother. That extra 70 horses did seem to make the trip back across Alligator Alley go just a mite quicker.
Old Jul 21, 2010 | 09:54 PM
TT Surgeon's Avatar
Unless you're testing a lot of aftermarket parts, probably not worthwhile. Just an exhaust and a basic flash, no need imo.
Old Jul 22, 2010 | 09:55 AM
vividracing's Avatar
Nobody can do a custom dyno tune unless it is the owner/holder of the Software tools. There is not live dyno tuning. You can however do datalogging. You would put the car on the dyno, make a pull and log the car. Email the company the file, they would make changes, and then send back a new file.
The reason this is barely done is. The 997TT files from most tuners have been used thousands of times so they are dialed. Ideally you have 4 real companies that can write files in the USA, 1 of them is south of you in FL. The rest of us are resellers and any shop can do the datalogging/dyno if they have the tools.
Old Jul 22, 2010 | 11:28 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Interesting statement. I assume Softronic is one of them? Which are the other three that you are referring to?
Old Jul 22, 2010 | 11:36 AM
EVOMS writes their own files and has a dyno. Todd at Protomotive writes his own files and has a dyno. Switzer writes his own files and has a dyno. FVD writes their own files.
Softronic does write their own files and allows others to use their flasher tool to load files. I might be leaving someone out like APR, GIAC... But those are the main ones.
Save the CUSTOM dyno tune for when you have a fuel system, big turbos, and really need it. Everyone has already dialed their ECU files for the stock 997 Turbo with basic mods.
Old Jul 22, 2010 | 11:43 AM
TTdude's Avatar
Thanks. I must say that flasher tool is very convenient!
Old Jul 22, 2010 | 11:44 AM
Not only is being able to flash the car via OBDII convenient, it is the ONLY way to do a datalogging custom tune
Old Jul 22, 2010 | 11:50 AM
TTdude's Avatar
That is true if you want to datalog using Durametric. There are also other datalogging programs such as ScanXL that utilizes a generic $10 OBDII cable with their own interface.
Old Jul 22, 2010 | 11:53 AM
TTDude - I want to hug you LOL. We did not fight online!
Old Jul 22, 2010 | 11:55 AM
TTdude's Avatar
XXXXXOOOOOO
