Exhaust louder on passenger side than driver side at idle? Normal?
Old Aug 28, 2010 | 03:04 AM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Hi Guys,
I have a FVD exhaust with cat bypass and I have noticed that passenger side pipe is louder than driver side at idle in sport mode. In normal mode the sound is about even. Is it normal?
Thanks alot!
Shawn
Old Aug 28, 2010 | 09:26 AM
TT Surgeon's Avatar
Check your lamps, one may be loose.
Old Aug 28, 2010 | 09:28 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Well...considering your hearing is OK this is not normal...there should be a leakage somewhere in the exhaust...
Old Aug 28, 2010 | 08:47 PM
Abby997TT's Avatar
Thanks guys! I retightened exhaust today and its still louder on the passenger side. Passenger side just sound crispier and louder.. I couldn't detect any leak, maybe it's the fvd thing? or something is wrong with my car.
oh it's louder on pass side in both normal and sport mode.
Old Aug 28, 2010 | 09:01 PM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
I have a Cargraphic Race (cat-less) and both sides sound the same, I went out started the car and walked back heard both sides a couple of time just to be sure.
Old Aug 28, 2010 | 09:15 PM
Abby997TT's Avatar
Thank you very much!
Old Aug 29, 2010 | 12:07 AM
TT Surgeon's Avatar
When you start it wrap your hands around each joint before it heats up to detect a pulse of exhaust gas. If the joints are not lined up correctly there will be a gap regardless of how tight things seem.
Old Aug 29, 2010 | 12:19 AM
Abby997TT's Avatar
Thanks! I just put my hand after the exhaust tip. seems like the exhaust gas doesn't come out as strong on the driver side. I think pressure is lost somewhere in the system and made it quiter ?
Old Aug 29, 2010 | 12:22 AM
Abby997TT's Avatar
Im going to try and feel the joint when the car cools down.
Old Aug 29, 2010 | 12:38 AM
quattrogeek's Avatar
quattrogeek is infamous around these parts
Your car runs like a champ.... I wouldn't worry too much about it.
Old Aug 29, 2010 | 12:46 AM
Abby997TT's Avatar
Thanks Sam! I think it's due to my diy install, I will have to take it apart and redo it.
Old Aug 29, 2010 | 04:17 PM
TT Surgeon's Avatar
Feel the joint itself for a blow- by type leak.
Old Aug 29, 2010 | 06:20 PM
Abby997TT's Avatar
There's definately a leak at the joint. I may have screwed up the joint on the pipe and it's not round anymore
Old Aug 29, 2010 | 10:40 PM
TT Surgeon's Avatar
Just try repositioning the clamp, rotate it 90-180 degrees then tighten it, usually works.
Old Aug 29, 2010 | 11:52 PM
Abby997TT's Avatar
Thanks! I will try that out tomorrow. Other wise I will have to buy a new pipe for the driver side or get a muffler shop to do it.
